-   -   GMC electrical question, fuse location. (http://forums.pelicanparts.com/off-topic-discussions/583093-gmc-electrical-question-fuse-location.html)
Joe Bob 01-01-2011 12:09 PM
If the 12 volt + lead on the trailer connector is dead.....where is the fuse located??
03 Yukon BTW....
A930Rocket 01-01-2011 12:29 PM
Read down the first thread a little bit. Seems to be in the engine bay and might have a dummy fuse in there now...
Trailer Battery Feed Fuse - GM-Trucks.com
2003 Yukon Trailer Fuse
Joe Bob 01-01-2011 01:12 PM
Yupperz, stoopid dummy plug in the fuse box. Of course it's a 40 amp special.
http://forums.pelicanparts.com/uploa...1293916271.jpg
Thanks for the help. The owner's manual and the Clymer's were worthless.....
911boost 01-01-2011 01:25 PM
The GM lead for the brake controller will have the fuse you need taped to it.
Joe Bob 01-01-2011 01:32 PM
Are you talking about the Electric Brake lead off the male adapter on the truck?
Think it's still there after seven years? :eek:
911boost 01-01-2011 01:46 PM
Nope, under the Dash, if the Yukon came with the towing package there is a plug that you connect to a traler brake controller. My Tahoe had the lead in the glovebox with the fuse attached to it.
Joe Bob 01-01-2011 01:49 PM
Thanks.....is the 40 amp fuse a two or four blade?
911boost 01-01-2011 01:50 PM
Mine was a two blade.
Joe Bob 01-01-2011 02:14 PM
Since I don't have electric brakes.......Do you think I can pull the fuse from Stud 2 (Accessory Power/Trailer Wiring Brake feed) and use that in Stud 1?
911boost 01-01-2011 06:54 PM
That is a good question, I am not sure. Does that stud control anything else? It would probably just be safer to get a new fuse.
Joe Bob 01-01-2011 08:24 PM
Did it to just see if I could get power....it worked. Swapped it back. Will get the proper 40 amp when it stops snowing.
The Stud 2 fuse was a smaller 30 amp.
