-   -   laptop computer/coffee not a good mix-help (http://forums.pelicanparts.com/off-topic-discussions/584615-laptop-computer-coffee-not-good-mix-help.html)
Rednine11 01-10-2011 04:26 PM
I'd write it off and order one. Tap water tends to be a tad corrosive. send me your email address and I'll find you one under 50 bucks NEW and send you a link.
Rednine11@yahoo dot com
And you are very welcome.
rfuerst911sc 01-11-2011 02:19 AM
E-Mail sent. Thanks
jeffgrant 01-11-2011 03:52 AM
I'd take the keyboard out and then clean it by hosing it down, multiple times, in a contact cleaner. As in drench it. The goal is to take all the crap that is now dried and caked onto the inside of your keyboard, and get it dissolved and flushed out.
Not the contact cleaner as in eyes, but electronic control cleaner, like this:
http://www.mgchemicals.com/images/product/401B-340G.jpg
There usually isn't much to a keyboard, so odds are it's just dirty, shorting out or sticky as a result, and not "fried". If something is fried, I'd bet that it would be on board the mother/daughter board, and not the keyboard, so replacing the keyboard might not help.
Hell, I routinely put external keyboards in the dishwasher when they get a little gummy and sticky. (The dishwashing is followed by a rinse of the above control cleaner).
The key is to get the proper cleaning solution that will dissolve and clean the residue that is there, and then dry quickly without leaving anything behind. That's what contact cleaner does.
$0.02
Rednine11 01-11-2011 05:41 AM
rfuerst911sc
I sent the email with a link to your keyboard from both of my email addresses
Only one got a reply from your spam filter so you should get it.
Your keyboard is 40 bucks with free shipping.
Let me know if you need anymore help
jeffgrant 01-11-2011 06:47 AM
By the way, if you haven't cleaned out the innards of the laptop with something like the contact cleaner I mentioned, that means you still have all sorts of residue inside the laptop that can and will cause problems.
Replacing the keyboard might only turn out to be a short-term fix.
I'd suggest doing a thorough cleaning with some contact cleaner to ensure that as much of the dried coffee residue as possible is removed.
Worst I had to clean out was a half can of Dr. Pepper from an ex-girlfriend. Not fun, but it was salvageable with a bit of time and $10 worth of cleaner.
Rednine11 01-11-2011 07:07 AM
he said the inside of the laptop wasn't wet. The keyboard took the spill and saved the system board.
rfuerst911sc 01-11-2011 02:16 PM
I have seen no indication that the coffee spill went anywhere other than the keyboard. About an hour ago I did the warm water rinse, followed with a rince of distilled water and finally rubbing alcohol. I'll let it dry for two days and see what happens.
Bobbi66 01-11-2011 04:44 PM
Just had to confirm what was mentioned earlier. At a recent party the subject of wet batteries came up, numerous people agreed that the rice trick really works to draw moisture out... good luck.
