AutoBahned
RWebb's Avatar
Win 7 Permissions
this GD OS won't let me move the files I need to get Excel customized the way I had it on my old XP computer.
it denies me access to move my personal.xls file over into C:\Document and Settings\... yada yada
when I try to Edit the Permissions it denies me the ability to do that
How get my damn programs set up??
PS - tried using a separate file mgr (PowerDesk) but that won't work either. MS help not helpful
Old 01-15-2011, 12:18 PM
slodave's Avatar
Docs and settings is not used anymore.
You want to be in:
C:\Users\_username_\My Documents...
Old 01-15-2011, 12:22 PM
Scott R's Avatar
Built-in Administrator Account - Enable or Disable - Windows 7 Forums
Enable the actual admin account, problem solved, forever.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 01-15-2011, 12:23 PM
AutoBahned
RWebb's Avatar
thx - that was fast
BTW - won't my old Excel from Office 2000 look in Docs & Settings like it did on my XP machine?
I note it is installed in a special folder for programs that are DDR "retarded" with an x86 tag on the folder name...
Old 01-15-2011, 12:27 PM
slodave's Avatar
No, it will look in the correct folder under Users.
Old 01-15-2011, 12:34 PM
AutoBahned
RWebb's Avatar
so I can only do this DOS MODE????
I have Win Home ver. 64 bit
Old 01-15-2011, 12:36 PM
slodave's Avatar
Huh? Not following.
Old 01-15-2011, 12:38 PM
AutoBahned
RWebb's Avatar
wait a sec....
is where I have all my data files - the ones I work on all the time
I don't want it cluttered up with a bunch of files that customize my Appl. pgms. ****
there is another subdi of the exact same name & path that is locked out...
Old 01-15-2011, 12:41 PM
slodave's Avatar
The directory structure was changed in Vista (7 follows the Vista paths). Ignore the C:\Documents and Settings. It's not longer used.
C:\Users\_username_\My Documents is like the XP C:\Documents and Settings\_username_\My Documents...
You can still drag and drop the files.
Old 01-15-2011, 12:46 PM
AutoBahned
RWebb's Avatar
that is where I have all my data files - the ones I work on all the time
there is another subdir of the exact same name & path that is locked out...
do I have to put it in the open one?
and what's up with the locked twin?
Old 01-15-2011, 12:47 PM
slodave's Avatar
The open one. I honestly don;t know why the shortcut is there and locked. I just ignore it and move on. Not something I care to get caught up with.
Old 01-15-2011, 12:50 PM
AutoBahned
RWebb's Avatar
... Not something I care to get caught up with.
words to live by
- being forced to clutter up my docs folder, together with the stoopid security crap, is making me an enemy of win 7
Old 01-15-2011, 12:54 PM
AutoBahned
RWebb's Avatar
ok, I did it
I know what's gonna happen at the bar tonite - friends are gonna ask what I did all day, then they'll get a smug look and say git a mac
Old 01-15-2011, 12:56 PM
If you got a Mac it'd work better.
Because on a Mac, you wouldn't be able to dig out decade+ old Office software and expect it to work. You'd be trained to just buy a new expensive bit of hardware and all new software to go with it every so often because they'd break backwards compatibility...
It's not a fair comparison.
People ***** that Microsoft isn't cutting edge, or never changes anything, and then in the next breath ***** that Microsoft did something little like moved a folder. Can't have it both ways.
If you're going to keep it, I'd suggest learning how libraries and the new start menu work, vs. trying to force it to work the old way. Using the new shortcuts, jumplists, search methods, etc. does work better. After a few minutes of adding some favorites to Explorer, etc., I can navigate and find stuff far faster than possible in XP.
Office 2000 isn't doing you any compatibility favors either, the new Home and Business verison of 2010 is $170 at Costco, and Home & Student is only $120 if you don't use Outlook.
Rob
1980 SC - 2011 Tiguan - 2018 Tesla M3P
Old 01-15-2011, 02:44 PM
The Unsettler
stomachmonkey's Avatar
Fixed.
"I want my two dollars"
"Brandon Won"
Old 01-15-2011, 03:18 PM
Yeah, sorta, it was only half sarcastic though.
You really can't dig out your Mac copy of Office 2001 and expect it to work on a new OSX Intel machine, it just won't. (Screwing around with virtualization doesn't count)
Rob
Old 01-15-2011, 03:29 PM
AutoBahned
RWebb's Avatar
in a prev. thread the hassle of learning a new interface seemed heavily outwieghed by the new bells & whistles in the 2010 Office versions
I might have to upgrade from 200 to 2003 versions tho.
oh yeh - Word crashed a few minutes ago - I opened Tools Autocorrect to see why the damn dictionary was not working
Old 01-15-2011, 03:30 PM
And I spent just as much time giving one of the local guys (who's in IT) a hard time about wanting to nurse along old copies of Windows and Office too.
I think equally on PCs and Macs that you should run whatever is reasonably current to the OS. I'd throw equal stones at someone trying to run Pagemaker on a new Macbook Air.
Rob
Old 01-15-2011, 03:32 PM
It might seem a little annoying at first, but it's really not all bad, it's just laid out horizontally instead of in a vertical drop down.
And you can hide the ribbon and use it like a menu if you really want to.
And 99% of the keyboard shortcuts still work anyhow.
It's worthwhile for not having compatibiliy issues, haven't to futz with the add on packs to read newer docs, being able to save to pdf and e-mail all with one button, etc. etc.
And actually, if I was to be against upgrading, I'd probably then switch to OpenOffice just since it's at least currently developed and has updates, etc.
Rob
Old 01-15-2011, 03:36 PM
The Unsettler
Thats not a really fair or even realistic scenario considering Office 01 was released for pre OS X operating systems running on PPC chips.
Todays Mac is a completely different animal. I would not expect an app written for a different operating system AND processor to function.
"Brandon Won"
Old 01-15-2011, 03:57 PM
