-   -   How do I fix this? (http://forums.pelicanparts.com/off-topic-discussions/587723-how-do-i-fix.html)
sc_rufctr 01-24-2011 09:51 PM
How do I fix this?
PLASTIC Headlights on a Merc! :confused:
Is it possible to buff these back to clear or do I need to buy new ones?
I know I can get a kit with the polish and stuff to fix plastic headlights...
But has anybody done this to Merc Headlights?
http://forums.pelicanparts.com/uploa...1295934523.jpg
http://forums.pelicanparts.com/uploa...1295934547.jpg
crustychief 01-24-2011 10:04 PM
I used the kit on my Land Rover. I was pretty satisfied with the results considering replacement costs.
Or you could just get some 2000 grit wet or dry sandpaper and work your way up to a fine cutting compound followed by some plastic polish.
Embraer 01-24-2011 10:09 PM
unless you pull the headlights to do it, be sure to tape the edges. if you're buffing them, you will burn through clearcoat in about .2 seconds
edit: i would do it by hand. forget the makita
Geronimo '74 01-24-2011 10:27 PM
I have the same problem with my VW, though not this bad.
Is there any way to prevent it from dulling again or protect the lenses afterwards too?
(sorry, not meaning to hijack)
Heel n Toe 01-24-2011 10:29 PM
Peter, what you have is a Benz, not a Merc.
If you had one of these, you'd have a Merc:
http://forums.pelicanparts.com/uploa...1295936917.jpg
http://forums.pelicanparts.com/uploa...1295936951.jpg
http://forums.pelicanparts.com/uploa...1295937209.jpg
:D
sc_rufctr 01-24-2011 10:47 PM
You'd need something to protect the plastic from the suns UV light.
Maybe a standard two pack clear coat would work... :confused:
sc_rufctr 01-24-2011 10:48 PM
:D
I like this one :D
Won 01-24-2011 11:22 PM
3M Headlight Restoration kit gets good reviews. I need to do the job on the bimmer soon. Some people paint the headlights with clear right after it's been restored with good results, I think I'll just leave mine and repolish in a few years if the need be. Or you can keep it shiny with the Maguires Plast-X.
repp 01-25-2011 12:14 AM
the headlight restoration kits work just fine in most cases.
iv run across a few that had to be sanded iv done around 15 pairs and only one was beyond repair
repp 01-25-2011 12:16 AM
I have used plastic buffing compound on a stand up buffer and its the best
sc_rufctr 01-25-2011 12:19 AM
Thanks... That's a good suggestion. I've got a bench grinder mounted on a pedestal in my garage. (I've got buffing mops for it)
The car belongs to a girl I've been dating for about 6 months so I want it to look perfect when I'm done.
repp 01-25-2011 12:22 AM
be very gentle as the buffing wheels like to burn plastic.
very light pressure if any at all and it should be fine
fastfredracing 01-25-2011 04:16 AM
I have used the kit with the sandpaper, and 3 different grade polish with good results, however, I recently ran out, and used a generic product that I got from the local Advance auto parts. It is a one part product, and does not require any buffing or sandpaper. Use it like wax/polish. Easy on, easy off. It works excellent, and is super easy. I cannot remember the name right now, I will look at it when I get to the shop this am , and post it up later.
Tim Hancock 01-25-2011 04:24 AM
I have always just used a 3M buffing compound (which pretty much works for anything from plastic to paint to aluminum) both by hand and by machine.
71T Targa 01-25-2011 07:02 AM
I did our Toyota's headlights with the 3M kit and they came out great!
http://forums.pelicanparts.com/off-topic-discussions/555279-how-polish-plastic-headlights.html
tchanson 01-25-2011 07:14 AM
Originally Posted by 71T Targa (Post 5806529)
I did your Toyota's headlights with the 3M kit and they came out great!
Another vote for the 3M Headlight Lens Restoration Kit
You need a proper speed drill, and its a little disconcerting when you first grind down the lenses to a completely opaque white, but the end results are pretty good.
30 minutes and about $15US, as I recall.
Tim
RichMink76 01-25-2011 08:16 AM
I just used the Maguires kit and it worked awsome. $24.99 at your local auto parts store. It comes with the sanding stuff, a buffer, and the polish.
Burnin' oil 01-25-2011 08:18 AM
I wet sand with 800, 1200 and 2000 grit. Couple bucks and like new.
Joeaksa 01-25-2011 08:19 AM
Originally Posted by sc_rufctr (Post 5806173)
I like this one :D
I grew up in a 1950 Merc two door coupe. Three on the tree with a flathead V-8, never should have sold that car!
A930Rocket 01-25-2011 08:53 AM
I used the 3M kit and it worked good but I'll be darned if the foam pad was wrecked when it got caught in one if those headlight nubs. It was worthless after that. Either cut them down smooth or be very careful around them.
peppy 01-25-2011 09:33 AM
I used the maguires kit with good results.
widebody911 01-25-2011 10:15 AM
Nothing like a girl with nice headlights...
Joeaksa 01-25-2011 10:42 AM
Especially high beams! :)
sc_rufctr 01-25-2011 05:53 PM
:D
http://forums.pelicanparts.com/uploa...1296006808.jpg
