Electricians, question about tripped circuit
I have a 15amp breaker in the box and when I run multiple items in the garage it keeps tripping. It's been really annoying lately so I've been really careful about running stuff and unplugging items while I use other stuff. Any ways, what if I just change out the 15 to a 20amp would that help or cure the problem?
How hard would it be to pull another line from the garage? Most likely it would even trip a 20amp if it only trips on power up when tools draw the most.
You getting any snow yet? |
You need a new dedicated line or maybe even a new box just for the garage. Call an electrician because this is a standard project for them.
Upgrading a breaker from 15 amp to 20 might cure the tripping problem....
The wire is most likely 14 gauge and rated for 15 amps. If you put more amps through that wire, it may melt/start a fire. Your insurance co will not look kindly on this.... |
Oh yeah the snow is coming and blowing around. Well what happened is I tapped into the circuit and added some new outlets not thinking it would be an issue. And it hasn't been for years. It's only an issue now because there is a heater in there now and the deep freezer kicks on/off and when I throw the air compressor or lift in there it trips all the time. What a pain in the butt because it's in the basement. It trips when stuff kicks on and sometimes it's fine and sometimes it trips when stuff kicks off.
I would pull a new line for the heater at least. Do your lights flicker when the compressor is running? 12 is used with 20amp but how long of run too?
http://img3.imageshack.us/img3/5734/...ratings9vd.png |
The run is short but there are many, 5? Yes the lights flicker when the freezer kicks on. I'm going to take that out of the equation soon because all these issues really came up when I installed it. Maybe I'll just get rid of it and put the stand up one back in the basement and be worry free...
Can you re wire the whole run with 12 gauge?
If not, then no.... |
Oh, I'm sure it can be done but it'll be a a pain now it's all insulated up there. I was trying to find the easy way out but I don't want to cause a fire. Probably running a new wire would be just as difficult. I'll call my electrician to see what he comes up with..
Definately pulling too many amps. Can you run a dedicated line to the fridge, even if it's in conduit on top of the drywall? It should be on one anyway.
With all that you're running, you may want two circuits in the garage. |
Bill,
I would see about running a dedicated circuit for the lift, if anything. I'm not good with 'lectrical stuff so I can't help you out. |
Ok, thanks guys. I won't change it and I'll call an electrican.
Do yourself a favor and have a sub panel put in the garage.
Or just replace the breaker that's become weak from tripping.
Sparks and flames? C'mon.. Hang an amp probe on it and see what you're really drawing. Or pay an electrician. |
A new 15 amp breaker would be worth trying if you don't have an amp clamp. Sparks and flames? Sure. That is how homes and garages burn down. Poorly installed and improperly upgraded wiring. |
It might be possible to detach the existing cable at both ends (and whatever staples exist along the way) and with two people, it may be possible to pull the new cabling through using the old cable. |
wait until you have a house fire in the middle of the next storm....talk about a pain.
get your electrician involved |
| All times are GMT -8. The time now is 03:21 AM. |
