-   -   Sealer for travertine tile? (http://forums.pelicanparts.com/off-topic-discussions/589564-sealer-travertine-tile.html)
HardDrive 02-03-2011 01:38 PM
I picked up some 511 impregnator for my granite countertop. I want to do my travertine floor as well. They have a 'porous surface' 511 product that seems like it would be right for the job, but the stuff is pretty spendy. Any other recommendations? (Cost isn't the issue, I just want to get the right thing for the job)
The floor was previously sealed at install, about 18 months ago. Don't know product, but I know the tile guy gave me an option for something with a little more sheen that would darken the floor up just a shade. I would like to duplicate the results.
Any help appreciated.
trekkor 02-03-2011 02:19 PM
What you have is perfect.
Use it!
KT
masraum 02-03-2011 03:03 PM
I asked on PPOT once about the best sealer. I was told to get the 511 stuff. I've got a countertop that's done with very porous 12" granite tile. I used the regular 511 stuff. It worked well. It seems to work much better than the other stuff that they sell that comes in the metallic green jugs.
I have seen stuff at HD that is for "wet look" sealing (enhances color and gives more gloss). I don't think it was the 511 stuff though.
I think that the 511 stuff that you have is probably the best, but I don't think they have a "wet-look" version.
Porsche-O-Phile 02-03-2011 03:41 PM
Doesn't glossy kinda defeat the point of travertine?
HardDrive 02-03-2011 03:51 PM
Its not glossy, its just has a bit more of sheen on it.
Thanks for the info guys.
trekkor 02-03-2011 04:30 PM
With expensive material or large areas it is always a good idea to do a test area before doing it all if you are unsure if you will like the finish.
KT
VFR750 02-03-2011 04:51 PM
I'm doing travertine too. How'd you hear about this stuff? Can i get it at lowes or the home depot?
trekkor 02-03-2011 06:01 PM
Try Home Depot.
KT
masraum 02-03-2011 08:42 PM
Home depot has the 511 stuff.
look 171 02-03-2011 09:12 PM
Around here, the gallon and the quarts are different. The quart has a higher VOC, the salesman told me that the quart bottle are better. OI am sure how much difference is it going to make.
VFR750 02-04-2011 04:07 AM
80 sqft = < quart for me. Thanks for the tip! Who knew PP Was the source for all useful info? :)
