-   -   Need quick help with epoxy/welding problem: (http://forums.pelicanparts.com/off-topic-discussions/591083-need-quick-help-epoxy-welding-problem.html)
speeder 02-11-2011 10:47 AM
I'm at yet another impasse with the 356, the engine is now ready to go in save for this little problem with the heater boxes. I've let this one go until now because I was busy with other things but now I need to solve it or install them with no working heat and deal w/ it later. (They were not previously working).
Basically, I need to attach this shaft to its flap/valve while it's installed in the HB. I took it to my welder and he could not assure me that his MIG welder would not warp/melt the flap even with a small/quick tack weld. The factory somehow crimped these on with a tiny weld, you can see the marks on the shaft and flap.
I either need to drill tiny holes in both parts and find small screws and/or use some super-duper epoxy that is heat-resistent to attach the parts together. I don't know my epoxy products and this would be a 1-shot deal, ie. if it does not work, the part would be really mucked-up.
New heater boxes are available for ~$300 each but need to be shipped. I need to install the motor today and would love to fix this box cheaply. Thanks in advance as always. :cool:
Here is the offending part:
http://forums.pelicanparts.com/uploa...1297450034.jpg
gtc 02-11-2011 10:54 AM
Know anyone with a spot welder?
Hugh R 02-11-2011 10:54 AM
If you won't be able to get at it again easily, I'd drill, tap and machine screw with lock washer and high tensile strength (2 hour) epoxy.
Shaun @ Tru6 02-11-2011 10:56 AM
JB Weld will work, as with all epoxy, surface prep is everything.
Seahawk 02-11-2011 10:57 AM
If it has to go today, JB Weld is fine...how hard is it to get to later?
speeder 02-11-2011 10:57 AM
Is JB weld really heat-resistent? (Never used it).
speeder 02-11-2011 11:00 AM
Any work involving heat exchangers is an engine drop + exhaust removal. Which is not the end of the world on these cars but it would be nice to fix this one before installing. The HE on the other side is junk so the engine is coming out again either way but I could at least have heat on one side.
speeder 02-11-2011 11:01 AM
That would be a great repair but for time reasons it's dead. Thanks just the same. :)
Tobra 02-11-2011 11:08 AM
what about drilling through it and rivet together, or grind a flat spot on shaft and use a punch to get flap in close approximation to flat spot
How different is that piece from a bug of similar vintage?
Eric 951 02-11-2011 11:08 AM
What about drilling a hole through the shaft/flap and using a cotter pin?
Tim Hancock 02-11-2011 11:11 AM
If you need to weld the flap to the shaft, I would simply drill a couple small holes in the flap where the original crimp indentations are and then I would simply rosette weld them with the tig welder..... Very simple IMO...
http://forums.pelicanparts.com/uploa...1297451460.jpg
Hugh R 02-11-2011 11:20 AM
Drill and cotter pin then, don't trust the epoxy in torsion.
Superman 02-11-2011 11:23 AM
Sure sounds possible. Maybe I'm missing something. Most if not all the above suggestions are excellent. What's so hard about drilling through both pieces and driving an interference-fit pin in there? Or as Tim says, open a couple of little ports in the sheet metal, and weld there. If the engine and exhaust will need to come out eventually, then you lose nothing with the gamble. Worst case scenario: The sheet metal gets a bit warped.
Aerkuld 02-11-2011 11:24 AM
I'd drill a small hole through the flap and the shaft and pin the two together. Possibly two small holes, one on each of the flats. Alternatively, do as Graham suggested and find someone with a spot welder.
wdfifteen 02-11-2011 11:31 AM
THIS IS THE WAY TO DO IT. There won't be any warping problems.
Short of this, epoxy the shaft to the flap. The problem with that is getting enough epoxy between the sheet metal and the shaft.
Tim Hancock 02-11-2011 11:33 AM
Rosette weld..... I promise it will work perfectly and is the easiest/quickest way to get the job done right. (unless of course you have a specially configured tongs for your spot welder that can fit inside the heat exchanger opening and still squeeze/weld the parts together)
Joeaksa 02-11-2011 11:39 AM
Spot welding is what I would use. Gotta be someone around with one. I have a small one from HF that I use...
wdfifteen 02-11-2011 11:46 AM
Maybe there is an issue of semantics here. I don't see how anyone would get a spot welder down in there.
It was swedged on to begin with. That might be an option, just deform the hole in the plate so badly that you have to hammer the shaft through it. Inelegant, yes, but it would work just fine. I would probably do just that if it was mine, but Tim's suggestion is the best permanent, fool proof solution.
Jared at Pelican Parts 02-11-2011 11:52 AM
I've used it to fix rusted out holes in mufflers. Surface prep is everything.
Seahawk 02-11-2011 12:26 PM
Honestly, Tim, WTF do you know...I mean, really;)
