New kid in town
71T Targa's Avatar
How do you tell if a used wheel is straight?
I am looking at used wheels to use with snows. If you're at a swap meet or somewhere else where the wheel isn't on the car, what's an easy way to tell if It's straight and true? I don't want to end up with something that wobbles or won't balance.
I wish I still had 9111113443...
Old 02-23-2011, 04:42 AM
a.k.a. G-man
Geronimo '74's Avatar
Put it on a flat surface? (face down, and look for gaps)
Old 02-23-2011, 04:52 AM
Roll it and watch...
JR
Old 02-23-2011, 05:31 AM
Kantry Member
oldE's Avatar
Unless you have a spindle to rotate it on, the only thing you might try is a continuation of Geronimo's advice. Do that and also see if you can detect any variation in the mounting surface in the wheel center and the flat surface you have the wheel resting on.
You have two ways for it to deviate from running 'true': either deformation of the rim itself or mis-alignment (usually through bending) between the center and the rim.
I wouldn't be comfortable unless I was able to spin it.
Les
Best
Les
Old 02-23-2011, 05:43 AM
New kid in town
71T Targa's Avatar
snip... mis-alignment (usually through bending) between the center and the rim....snip
This is what I am most concerned about, and what would be the most likely situation.
People buy used wheels all the time, do they just take their chances?
Old 02-23-2011, 05:57 AM
Arizona_928's Avatar
Look at the wheel weights. If there is a lot on one side it's bent. If there is weight on one side of the wheel, and weight perpendicular or to its 11, or 1 O'clock. Then it's also bent.
dolor et pavor
Copyright
Old 02-23-2011, 06:52 AM
Put it up next to a wheel of the opposite gender?
Old 02-23-2011, 08:01 AM
New kid in town
71T Targa's Avatar
HA!
I am looking for Miata wheels.
Old 02-23-2011, 08:18 AM
Originally Posted by 71T Targa View Post
HA!
Well, those are never straight. Just try to find four of them that get along.
JR
Old 02-23-2011, 09:02 AM
