whiskyb's Avatar
Home Audio
I know their are some pretty smart audio guys hanging out here so maybe you can help me.
I currently need to replace the receiver in my garage. What I want to be able to do is play audio in the garage on one zone and have 3 more zones controlled from the garage as well
All zones would be playing the same content just need the ability to control volume and on/off
Of the 3 additional zones 2 are already hard wired and the 3rd could be or wireless is an option
I have looked at the sonos but think it might be a bit much as the way I see it I would need 3 or 4 of the zone players at 500 each. I really did not want to go that high but if I had to I could.
Any insight or links would be great
Whiskyb
69 911
Wasaga Beach
Old 03-03-2011, 05:32 AM
sca037's Avatar
Receivers designed specifically for many zones (3+) can get expensive fast, so maybe a conventional receiver coupled with a multi-zone output switch like this one would be a more cost-effective solution;
Amazon.com: Sima SSW-L6EX Speaker Selector for 6-Sets of Speakers: Electronics
Brian
'85.5 944 (sold and will be missed)
Sport seats, LSD, sways, 7 & 8" Fuchs
Old 03-03-2011, 06:37 AM
Born to Lose, Live to Win
ramonesfreak's Avatar
for applications like a garage, i have used old (1970's, 1980's) amps that have a (i believe its called) line level output on the back. i then chain the amps together going from the line level output of the first amp and into the aux input of the next and so on...this way you can have independent volume control per set of speakers
i dont like using new stuff in the garage due to extreme temp and humidity etc...
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 03-03-2011, 06:43 AM
whiskyb's Avatar
I think that is close to the one I found. It looks pretty good for what I want to do. Impedance seems to be the big thing to keep stuff working. I would also love to find a few older amps at a garage sale. Those big heavy things last forever
Whiskyb
69 911
Wasaga Beach
Old 03-03-2011, 07:05 AM
you can get the old ones..like silver face pioneer etc... at good will and ebay for less than $50. but sometimes they work, sometimes they dont, sometimes they work fine for a while and then quit. the capacitors leak
1983 911sc
Old 03-03-2011, 07:24 AM
Z-man's Avatar
I have one of those attached to my home theature system to route music to my kitchen and outdoor deck. Future plans include wiring up the bedrooms and possibly the garage.
Works very well.
Three things to keep in mind:
1. Keep in mind that the speaker switch is not a powered unit, so you may need to turn up the volume on your amp a bit higher in order to take advantage of the volume controls on the speaker switch.
2. Depending on the distances of the speakers (speaker wire length) as well as the additional wireless set of speakers, you may realize an echo-effect which occurs between sets of speakers. Not an issue if you only hear one set of speakers at a given time, but it can be an issue if the rooms are next to each other. (It will sound kinda like music playing in an arena)
3. If you are using a newer low end HTS, and are planning on connecting your garage system to the "B" channel, then most of the low-end theature systems will not support a digital audio signal on the "B" channel, only analog.
Hope this helps,
-Zoltan.
2010 Cayman S - 12-2020 -
2014 MINI Cooper S Coupe - 05-17 - 05-21
1989 944S2 - 06-01 - 01-14
Carpe Viam.
Old 03-03-2011, 08:52 AM
