Extrude hone - to do or not?
Interested in hearing any comments on the topic from people with experience with it.
Thanks much Tad |
Are you running carbs or FI?
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
Senior Member
FI here, and also interested in it.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
extrude hone
FI
thanks |
From what I've read, you need to get some feedback on who's doing it. Some parts have been mauled, while others do a great job with it.
I was told not to do it for a carbed engine.
I'm considering doing my 930 intake when I go to EFI, from what I understand it helps equalize the flow to each cylinder. I think the benefit depends a lot on the original design of the intake. The guys from TurboKraft are members of this board and post in the 930 forum, they may be able to offer some insight.
It always seemed like a lot of money that could be better spent somewhere else. If you've done everything else then sure, go for it.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Still Doin Time
MO is all the early euro intakes (FI) were sand cast aluminum (cheap) but hard to control internal runner size/volume because most were cast as two pieces then mated. Looked pretty good from the outside but inside I've seen mis-matched joints and rough casting seams.
If you are looking to improve performance overall, then this would be a great addition as the process mostly equalizes runner volume, which even in a mild street motor makes a big difference in tuning
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
You do not have permissi
The Carcraft articles mentioned a rough surface in a carb'd intake creates tubulence and improves mixture.
Not sure what the trade-offs would be, or if that limits overall flow: aka the golf ball therory. Port matching/beveling with a grinder would probably be a good first step, or manifolds designed for desired operational rpm range. |
Information Junky
The idea has always struck me as gimmicky. ...somehow a blob of grit is supposed to magically make a better pathway than what the engineers (and their testing & computational fluid dynamics) came up with.
That is, simply opening up the tube might sound smart (for some) but really, there is more involved with efficient intake than just a high flow number.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
I had my 88 3.2 Extrude Honed. Also had other stuff done(motor rebuild) so it is hard to tell
if just that alone made a difference. I had EBS flow match and rebuild injectors, Steve Wong Chip, Fabspeed Pre Muf and dual out muffler.This with the rebuild has been a very good motor, runs great and the one thing I have noticed most is that is runs cool, I mean temp needle stays about mid point all the time, AND I live in Louisiana with 100 degree temps with 95 percent humidity all summer.Don't know if that means anything,but I like it ! |
to do or not...
Thanks for all your input, much appreciated.
Cheers |
