Guitar pickup question
I have a Highway 1 Fat Strat which I like but I was thinking of ditching the humbucker and going with single coil at the bridge. I have an Epiphone Dot that I bought (2001 model so it's Korean which I hear is a better guitar than the current Chinese ones). Anyhow the Dot sounds sweet with the humbuckers so I was kicking around the idea of converting the strat to single coil.
Can I just put in a single coil pickguard with the pickups in it or it the body of the guitar different between a HSS strat vs a SSS strat?
Rick 1984 911 coupe |
You'll lose some of the functionality of the switch. Humbucker is 4 wire the single coil will be 2 wire. If the pups mount to the pickguard, then it's probably a fairly easy fit.
You normally pick up a guitar by the neck.
Band.
Have a tech put a "coil tap" toggle switch on the Humbucker in the Strat and you can have your choice of humbucker or single coil sound at the bridge without changing pickups.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
What Jeremy said...
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Oh, didn't know that! Sweet!
N-Gruppe doesn't exist
Ted '70 911T 3.0L "SKIPPY" R-Gruppe #477 '73 914 2.0L SOLD bye bye "lil SMOKEY" ![]() "Silence is Golden, but duct tape is SILVER.” other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L |
