-   -   Motorcycle Top Speed Help! (http://forums.pelicanparts.com/off-topic-discussions/602814-motorcycle-top-speed-help.html)
Mr.Puff 04-13-2011 08:35 PM
I am installing a new engine in my CL175 and it has different gear ratios! My goal is to be able to go 65 MPH at a comfortable RPM.
The ratios:
Initial/Primary 3.33
First 2.769
Second 1.882
Third 1.4
Fourth 1.13
Fifth .96
Front Sprocket 14
Rear Sprocket WE DECIDE!
The rear wheel circumference is about 80in. I may be able to install a thicker rear wheel.
The bike redline is 8,500 RPM.
I have already done the calculations, but I want to double check.
The original gear ratios were:
The ratios:
Initial/Primary 3.7
First 2.769
Second 1.882
Third 1.45
Fourth 1.173
Fifth 1
Sprocket 2.5
Redline 9,500 RPM
tevake 04-13-2011 09:27 PM
Sorry no help here on the gear ratio. Is that the smallest twin cyl engine that Honda sold here? How about some pics.
Cheers Richard
on2wheels52 04-14-2011 03:17 AM
"Sprocket 2.5" ?
I'd suggest having the 'final' ratio pretty close to what the factory used.
Not sure what you mean by comfortable RPM, I'm thinking to pull 65 you're going to have to have it zinging pretty good. I have an old 400 twin I don't like going much over 65 with for any extended time; too buzzy for me, though I'm sure it wouldn't bother the motor to do so.
Jim
dlockhart 04-14-2011 03:39 AM
very helpfull
Gearing Commander: Motorcycle Speed, RPM, Chain & Sprockets Calculator
LakeCleElum 04-14-2011 04:16 AM
Years ago, when I was road racing, I wrote a computer program in BASIC that allowed you to put in sprocket size, tire size, etc and get the rpm vs speed.
But from experience, just up one tooth on the countershaft sprocket, or 3 teeth smaller on the rear.......That will lower your rpm by up to 500 at 65 mph....If you make more drastic changes, you won't have the torque to overcome the wind resistance and be shifting down all the time. Shifting down defeats your purpose...G'luck
Mr.Puff 04-14-2011 02:08 PM
I made a spreadsheet yesterday. The bike was rated at 81 MPH max. I matched the speed on my spreadsheet at redline for both engines. It turns out the stock sprockets were 14 and 35, and my new sprockets should be 14 and 36 to 37 depending on rear tire size.
