The 2 Stage is basically 2 A/C units in a single package. You can run the small unit, the large unit or both, giving you some turndown but also some big cooling capability when you need it. The VFD unit uses a different type of compressor and a variable speed control on the compressor, along with a variable expansion valve. The unit can run from 60% of nameplate capacity to around 115%. So a nominal 4 ton unit runs as a 2.5 ton unit all the way up to a 5 ton unit. The VFD also soft starts the unit, preventing a huge inrush current. |
Wait, you guys have a multi-story house with multiple AC units, and you're complaining? I've got a 2 story, 2000sf house built in '67 with crappy insulation. I've got one unit. I thinkits either 3.5 or maybe 3 tons. I run the fan in the "on" position from Mar until Nov to keep the temp differential between up and downstairs from being extreme. You guys should consider yourselves lucky.
Here's some interesting tidbits from the 'net. Quote:
Like you said, heat rises and the roof has all that surface area exposed to the hot sun (verses cold earth of bsm't). Sounds like to me things are sized right, but you need some adjustments made to balance the system. |
I would be hesitant to simply throw a bigger unit at the problem. Unless ductwork is upsized, you'll may not see the desired results. Before throwing more tonnage, make sure the ductwork is sealed and insulated properly. Consider adding radiant barrier to the attic, or convert to an unvented attic. When the ductwork is in a vented attic, you can lose as much at 20% of your heat and A/C output. Also, those losses are greatest when you need the conditioned air the most. If, after addressing efficiency and waste, you find a need for more output, consider a ductless mini-split. Your systems will be staged to maximize efficiency and flexibility. jurgen |
| All times are GMT -8. The time now is 01:36 PM. |
