-   -   .Net Developers: Hard to learn? (http://forums.pelicanparts.com/off-topic-discussions/613293-net-developers-hard-learn.html)
Brando 06-10-2011 10:46 AM
Afternoon gents. I'm not sure how many of you are developers/programmers or specifically MS .Net developers/programmers, but I was curious how difficult it is to pick up .Net development for web applications? My company is moving towards providing services through the Dot Net Nuke CMS and I would like to be able to develop/design object for use in the portals. Only problem is... I don't know .Net.
I've done all of my development in a LAMP environment... Apache for web hosting, Perl/CGI, PHP and MySQL for DBs. I would basically need to learn beginner to intermediate. There is also a high probability that the company would sponsor should it require funding. :D
Thanks!
id10t 06-10-2011 10:57 AM
I maintain that 90% of programming is problem solving. Solve the problem, and you can look up the syntax.
I know we have online classes for the C# stuff, but not sure on the .net stuff - esp the asp(x).net that you'll be using in a web environment.
Sending a PM w/ info on getting some books at no cost on it ...
Brando 06-10-2011 11:04 AM
Thanks id10t! Immense help. Free resources are always excellent!
masraum 06-10-2011 11:28 AM
You guys are special. I'd like to learn to do some programming. For me, I would probably find the most use from something like PERL. The problem is that I find programming torturous. It's one step up from a self vasectomy with a rusty spork.
I think I was ruined by basic years ago (typing a billion lines of code for a dot to bounce across the screen) and Fortran 77 in college. I hear that things are much better these days.
I'm glad you crazy folks that code are around so I don't have to.
einreb 06-10-2011 01:19 PM
Thanks!
My guess is that learning .Net will not be as big of an issue for you as getting comfortable with Visual Studio.
Visual Web Developer is free to download.
krystar 06-10-2011 02:01 PM
learning C# syntax isn't the challenge if you're already LAMP comfortable. it's engineering a .net project the "correct" microsoft way instead of just what works.
Brando 06-10-2011 02:31 PM
Krystar... so freakin' true. I hear from the MCSEs here about the "Microsoft ™®" specified approved method to solving a problem, then the 500 other *correct* methods to solve the same problem. I love the freedom and viability of programming in PHP to tackle any problem from 50 different directions. I don't believe in regimented programming (do it this way and ONLY this way, even if it is bloat).
gwood 06-10-2011 09:12 PM
You get a ton of Telerik ajax controls free with DotNetNuke, which simplifies your UI designing considerably.
rnln 06-11-2011 12:09 AM
I don't know what lamp is. If you have been done OOD/OOP, then it's better for you. If you are so use to procedure programming, then it's take a little harder. Concentrate on the .net frame work, which I had hard time to get. Most of my java friends think it's a POC when they converted to .net/c#.
slodave 06-11-2011 12:12 AM
LAMP (software bundle) - Wikipedia, the free encyclopedia
