-   -   Best process question (http://forums.pelicanparts.com/off-topic-discussions/619264-best-process-question.html)
romad 07-14-2011 07:19 AM
What is the best(quickest) way to assemble something with multiple steps of equal effort/time?
a) Complete all required steps for one unit at a time.
or b) complete one step at a time for all units
stomachmonkey 07-14-2011 07:24 AM
How many units and how many individual steps per unit, how complicated, how many parts?
If just a few I don't think it matters.
If 10 or more then I would build at least one or two completing all required steps just to make sure I understood all the steps then I'd go to completing one step at a time for the balance.
You want to avoid a misstep that makes you have to backtrack on multiple units.
Noney 07-14-2011 08:02 AM
I believe it's a generally accepted practice to complete an entire unit before moving on to the next one. This prevents you from applying the same mistake to multiple units and then having a bunch of completed, yet incorrect, units. No matter how careful you are, there's always room for errors and the hope is that if you begin making an error as you complete units, you'll catch it in time and not trash your entire assembly run.
cashflyer 07-14-2011 08:09 AM
You'll need to take it up with the shop steward.
Rich Lambert 07-14-2011 08:10 AM
What he said...one piece flow.
Porsche-O-Phile 07-14-2011 09:25 AM
Subcontract it and add 5% markup.
IROC 07-14-2011 10:39 AM
Completing one step at a time for all units would also require you to have all of your inventory there at the beginning (not practical or cost effective) where completing the entire units one step at a time allows "just in time" inventory management and continuous process improvement. Sorry, had to through in two buzz words. SmileWavy
wdfifteen 07-14-2011 04:13 PM
A factor to consider is how long it takes to prepare for each step. If it takes a while to get the tools, get in position, put tools away, clean up, etc. for each step you might be better off getting set up, doing all of that step, clean up, put tools away, etc, and then moving on to the next step.
widebody911 07-15-2011 07:08 AM
This. I make various repro parts, and it's just me, so I'll make batches of each of the components separately, and then assemble a final unit all at once. I'll do a few complete units, then paint them all at once.
Z-man 07-15-2011 08:03 AM
This. Inventory management, especially in a just-in-time system is critical.
Addtionally, by assembling multiple units at a time, one can introduce concurrent operations to the mix, with careful coordination of the entire process. This should allow a quicker completion of the total number of units being built, provided there is sufficient workforce to support concurrent processing.
Geez - I think my MBA studies are finally starting to pay off! :)
-Z-man.
