least common denominator
RE: Old car vs new I have a Hyundai $13K new 10year/100k mile warranty. My friend has a 66 Pontiac... can't go a month or two without it being in the shop... besides the costs of parts and labor there is the time spent running back and forth and not having transportation when the car is down. Just sayin...
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
Well, first off, a '66 Pontiac should run forever if it was maintained at all. But, you can't compare a 44 YO car to the typical older used car that can be had for nickles on the dollar. If you choose carefully, you can pick up a good used car from someone that took care of it.
Take my Jag: I'm in it less than 5K with everything I spent so far including taxes. It's a very nice ride. I'm hoping to find another to squirrel away. |
Drink lime or lemon juice to get rid of hiccups.
Since I am in the middle of redecorating the house; if using oil based paint put the brush in a plastic bag and leave it in the freezer until next needed-seems to work for quite long periods.
Too many cars, not enough moolah... |
Regular Coke will dissolve battery acid from the terminals.
AVON Skin-so-Soft can be used as a bug/tar remover. It also removes burnt rubber from quarter panels(burnouts at the drag strip).
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Registered Usurper
...and rust off chrome
...and road film on windshields
'82 SC RoW coupe |
Control Group
Alcohol is infinitely soluble in water I believe, works as anti-freeze too. Put a few tablespoons of alcohol in a ziplock bag with water, will get really cold but not freeze, may need to mess with ratio.
If you mix dish soap, baking soda and hydrogen peroxide, it will de skunkify your dog if they get sprayed.
She was the kindest person I ever met |
Urine kills nail fungus. (I have since been informed this is not true.)
White wine removes red wine stains. (Apparently not true either!) Mechanics citrus soap removes grease stains from clothes. Last edited by LWJ; 07-31-2011 at 06:58 AM.. |
Double tap.
Control Group
Urine does not kill nail fungus.
If you don't have a vacuum cleaner, nail a 12" piece of 2x4 to a stick and run it back and forth over your carpet to make it look like you've just vacuumed.
Control Group
Is that from a "you might be a redneck" bit?
Senior Member
"Lime and Bitters" is the traditional cure you can get from any bartender worth their salt. It works. Or so I've heard.
![]() The only thing I know that removes red wine stains is boiling water. If you put soap on it, the stain will set and never come out. Boil water, and pour the boiling water on the stain until it's gone. Hot water does not shrink or mess with wool. What messes with wool and shrinks it is agitation. The agitation of a clothes dryer, for example, or even the agitation of a clothes washer. Wool is a curly filament, and it ties itself in a knot when agitated. Without the agitation, there is no shrinkage problem. Boiling water poured through wool fabric will remove a red wine stain without messing with the fabric.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Gon fix it with me hammer
So does sucker punching the hicker uper in the gut... It works too, i can proove it to you.
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Put mustang on a burn will help heal faster.
2015 GLK (Momma's ride) 2016 F-250 2001 BMW M5 65 CSX 427 Roadster |
Tobra. Thanks for the clarification. Good thing I haven't been peeing on my toes!
![]() My supervisor bought me a set of black tools for work... BRILLIANT! ![]() For red wine stains... soak garment in red wine...
But I've heard Vick's Vapo-Rub works as well as prescription ant-fungals.
http://www.tipking.co.uk/tip/5498.html
--------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain |
Control Group
I have also heard the vicks thing. Have actually seen pretty significant improvements with that, tea tree oil too.
AutoBahned
all sorts of fabulous anti-fungal plant compounds in the tropics -- we just have to ID them (and then safety test them)... before they go extinct.
