C-2 Doors on a '78 SC???
Will the doors from a '92 C-2 Coupe "bolt right up" to a '78 SC? Will the interior items, such as door panels, pockets, handles, etc. easily/directly attach to the newer doors? Are the hinges and closing/locking mechanisms identical?
If no to any of the above, what's involved in doing this?
Thanks!
Michael
'98 Boxster in Ocean Jade Metallic
Old 02-21-2002, 01:54 PM
Senior Member
Hello
Yes it is somehow a direct bolt on. You will have to drill some holes for your window mechanismen but you will find those places marked with a little recess for direct drilling.
You also will find retangular holes for the plastic rivets used in 78 on doors ( pre 78 are boltet direkt to the inner skin or have the little sliderplates with the dual threats on the lower edge ).
While you are there reinforce the rear door pcket flap anchor with a secound sheet from the rear ( I have them as ready threated units and just use a rivet in the middle ).
Now a other problem is that the door will not have the same curve on the lower a-pillar and not press the interiour light switch deep enough. You need to glue a piece of rubber onto the door ( see 356 ) or shim the lightswitch.
There was a rumor that Porsche will sale longer switches to solve that problem "cleaner" but never heard from that the last 10 years again.
Grüsse
Old 02-26-2002, 01:29 AM
Thanks Roland,
Can I remove the electic window regulators and switches, and install my manual window regulators and cranks?
Michael
Old 02-26-2002, 06:24 AM
Senior Member
Hello
Yes
You will have problems fixing the front form the upper long pad as the frontend is reshaped and your screw will not be long enogh to see some metall.
You can buy the support brace or use a longer screw.
You also need a long plastic cover for the rear windowframe screw holes ( Was two round holes pluged with rubber ).
And you will find many holes you will not need.
Grüsse
Old 03-01-2002, 12:44 AM
Thanks again for the great info Roland! I think this is a little bit more than I want to tackle.......
Michael
Old 03-01-2002, 04:46 PM
John Brandt's Avatar
why is this off topic?
Old 03-07-2002, 09:50 AM
Shakenbake's Avatar
Moderator brain fart probably.......
Shakenbake (Chris Baker)
Need new toys
2001 VW Jetta VR6
2003 Sea Ray 200 Bow rider
Old 03-09-2002, 06:17 PM
Senior Member
My mistake
See:
http://www.pelicanparts.com/cgi-bin/vb/showthread.php?s=&threadid=60597&highlight=C2+Doors+on+a+78+SC
Old 03-10-2002, 02:42 PM
