-   -   Please Help: my sunroof does not work (http://forums.pelicanparts.com/off-topic-discussions/623875-please-help-my-sunroof-does-not-work.html)
911euro 08-09-2011 06:15 PM
Could you please give me some ideas on how to diagnose a sunroof's problem? I just replaced with new cables, cleaned the rails and new seals but when I turned on the switch, no movement, no sound :mad:
I also replaced with a new fuse but no luck. How do I check the motor? Any other ideas?
Please help.
Tom :D
masraum 08-09-2011 06:42 PM
Sounds like this should be in the "911 Tech" section (assuming it's a 911). You will probably get some answers here, but the tech section would probably be a better spot for it.
How about the switch? Are you getting power at the switch, the motor, the fuse? Is there a relay?
enzo1 08-09-2011 07:10 PM
post your ??? here if its a 911 Porsche 911 Technical Forum - Pelican Parts Technical BBS
911euro 08-10-2011 07:44 AM
thanks Steve and enzo1.
I checked and replaced the fuse. I will post my question as you recommended.
