The Big Green Egg
What a great new tool for the back yard
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug 1984 Mercedes 500 SEC 1991 Mercedes 420 SEL 1992 Ford F-350 Dually 28' Pace Trailer |
White and Nerdy
My Dad has two small ones, and a big one, cooks some great stuff, very low energy to.
Shadilay. |
My parents had one in the 50's. I think they bought it at a high end dept store much like Neiman Marcus is today. The hinge was simple and the little lid thingy fell off all the time and broke. It won't work w/o the little cap. The bottom vent was just a ceramic plug that you cocked in place to regulate the flow of combustion air.
All in all, a very trick device. Ours was red. |
Evil Genius
Overpriced for what is it..........I've seen people make them from 2 terra-cotta planter pots turned upside down on each other.
Life is a big ocean to swim in. Wag more, bark less.
A Man of Wealth and Taste
I have one, as well as a David Klose Steel Drum with 1/4 place, fire box at 1/2 plate.
The Green Egg is a direct heat unit. It imparts a different taste than the indirect heat units. The limitation to the BGE is the amount of Q that it can do. When I want to make a single rack of ribs it is perfect. I also use a Weber Kettle for Grilling, as it is easier to use. Lump Harwood Charcoal is the best to use. I buy 40 lb bags for $12 a bag. Oak or Mesquite.
Copyright "Some Observer" |
Another die hard egg head here.
Love it! We actually went online and downloaded a plan for an egg table. I ended up building it out of red oak. That silly table, with all of its simpleness cost me as much as the darn egg! Anyway, the egg is the only way we do shish-kabobs now. And it is built like a tank. Tons of good recipes for the egg out there. You will love it.
tk 08 911 C2S - Sold 13 Audi A4 14 Jeep SRT 500HP |
that new WEBER unit is making a run at the BGE's market share. even ATK ranked it higher recently in a show.
i want an egg tho..very cool setup with it nestled into the cutting block table.
poof! gone |
I have a Bubba Keg grille which basically is a metal version of the BGE. Double wall with insulation in between I really like it and it was much cheaper. They all have a place in our backyards.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
FUSHIGI
egg'n for the past 4 years...DIG It!!
another round please
I saw a contest the other day that said the "big green egg" was valued at $800.00. Is that true? Seems very high to me for what you get.
Getting old is not for wimps. |
Evil Genius
Old Dave's Po-Farm: Ceramic Flower Pot Cooker
Build The Cadillac of DIY Flower Pot Smokers to BBQ in Style
Un-Registered User
Which Weber unit are you referring to?
Don 1988 Targa |
![]() Weber Smokey Mountain |
Problem with those tin units is that the metal is toooo thin. It dissipates heat very quickly and one has to constantly tend the fire. With 1/4 inch plate on the body and 1/2 plate on the fire box of a David Klose or BGE one can easily maintain a constant temp over many hours. Consistency of temp is what helps to turn out great Q.
The water bowl in the bottom of the unit is designed to maintain heat consistency.
I agree 100%
From another forum Quote:
FUSHIGI
In my mind, better heat retention equates to less air needed for combustion resulting in food that is more moist and tender. I like my egg a lot but am not married to the idea that it is the only good option for grilling. It cooks very well. Unless I break it, I shouldn't have buy anything else again. For me, it's a reasonable investment...even better if it's second hand and priced accordingly.
My cast iron gas grill is on it's third set of burners and I can't see putting in a fourth. |
Un-Registered User
I've got the Weber Smokey Mountain. It has gone 12 hours at a time and maintained 225°. I need to add a few briquets after about 9 hours. It has extremely good control of temperature.
Don 1988 Targa |
Information Overloader
Saw one of those horizontal cookers at Bass Pro Shop, Tabby. How well do they work?
I had a New Braufels Bandera. Vertical unit with fire box on the side. Never could do a decent Pork Roast on the thing. Lots of heat disapation as the metal was thin. Every hour had to put in more fuel to keep the temp up
Grease tends to drip down on the the stuff on the lower racks. If U had stuff to hang and smoke it would have worked better.
