-   -   Fan switch question.... (http://forums.pelicanparts.com/off-topic-discussions/626891-fan-switch-question.html)
Roosterrusek 08-27-2011 01:43 PM
Yo, I have and attic fan, it has an Off - Low - High switch that is going bad. Any reason I cannot get a dimmer switch and put it on there?
imcarthur 08-27-2011 01:52 PM
No. Light dimmers vary the voltage which won't work with a motor. You need a proper fan switch to vary the speed.
Ian
Roosterrusek 08-27-2011 02:03 PM
Ian
Gotcha...makes sense. Thanks
968rz 08-27-2011 02:21 PM
+1 on Ian's comment. A normal light dimmer will hum very loud and get hot. Buy a heavy duty 3 speed fan switch.
rick-l 08-27-2011 02:25 PM
Need more info. It sounds like you have a (fairly big) fractional horsepower motor that now has 3 wires going to it. That type of switch should not be very expensive.
Bob Kontak 08-27-2011 04:17 PM
Tried that back in the 1970's on a Garrard turntable that played too fast. No dice.
