Best way to drill straight consistant holes in wood?
I want to organize my tool box and specifically my sockets in the top. What I want to do is make some wooden 1" of 1/4" with short dowels to hold them by size, depth, etc. I'm not impressed with the plastic socket holders and don't think I can get them all in with them any way.
Not having a drill press, I've used an egg cup bushing holder some and it works well, but I think it only goes to 1/4" (which should work for what I need). I've looked at used drill presses, but don't want to spend the money for a nice one, question the cheap Harbor Freight, Northern Tool, etc. and really don't have the room for one right now. That said, a cheap bench top model costs about $75-85. It would last for this project and the small amount of work I'd use it for. Here's a used one: http://charleston.craigslist.org/bfs/2539347345.html What is the best way to drill nice perpendicular holes? Or does anyone have an idea for organizing the sockets? I can get the egg cup holder and a 1/4" bushing for $25.00. Ideas? Last edited by A930Rocket; 09-03-2011 at 04:59 PM.. |
magnetic strip, like on the tool trucks. i use the long steel strips with the metal u-clips pop riveted to my drawer.
A benchtop drill press would be fine for that project, but if you shop some more, you can get better and cheaper than the CL ad you linked.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
78 in a '71
How can you justify passing up a legitimate excuse to buy more tools??
On glide path...... 1971 911 T Targa 2013 Ford Fusion Titanium AWD 1982 Volvo 245, 1996 Ford F-150 |
That drill press looks like overkill for what you plan to do, but the price seems good assuming it doesn't have any issues. However, one of the bench height HF drill presses would be more compact and drill vertical holes just fine. Remember, you need drill bits, vises and clamps as well..... and a chuck key AFAIC see.
If that's the only project needing a drill press, you can buy an inexpensive stand that holds a portable/electric drill. Here's a bunch on eBay: Sherwood |
Port-a-lign would work too since you already have a drill motor.
Scott '78 SC mit Sportomatic - Sold |
Or a hand drill stand:
![]() Attaches to drill chuck. Good for vertical and horizontal drilling and any angle between. The rails guide the drill. The adjustable stop controls depth of cut. I have one. Works fine for what it is. Sherwood |
That looks handy. I'll look for one of those.
Thanks! EDIT: Just found one for $28 on ebay, but the same new for $28 elsewhere. Is it made of metal? Last edited by A930Rocket; 09-03-2011 at 07:26 PM.. |
That's what mine looks like too...
Doweling jig? Around $20
--------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain |
No, high impact plastic, but mine is reinforced at the threaded parts with metal inserts.
drilling holes..........
buy yourself a dowel jig. they are not expensive and will allow you to choose from several different sizes. Look around and you should be able to find one that meets your needs.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Platinum Member
Sounds like an excuse to buy a milling machine to me......
Seriously, use a brad point drill bit, and stick a bubble level on the back of your drill, or eye it up with a square. You don't need precision for this one..... |
Slackerous Maximus
Buy...a.....drill....press....you......cheap...... ass......
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
Actually, if you don't need a drillpress, why not just go to a cabinet shop...they probably wouldn't charge much for what you want.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
I have a sickly little drill press and I was drilling 1/4 steel plate this week. Nothing wrong with the little units but the pulley adjustment for speed is not what it should be. Only 3 speeds and the low is not low enough. |
Just buy a 1/4 fornester bit at any home depot. $6.00 and self guided perfect peg holes will the result!
I've driven alot of crap to get here man! |
A930Rocket...
You are welcome to use my drill press here in Summerville, I am available most any time. Glenn |
Thanks Glen. I appreciate the offer.
I need to get some 1x or ? and lay out what goes where first. I got out sniped on these bushings last night. Looked like a good deal. Last edited by A930Rocket; 09-05-2011 at 05:04 PM.. |
