Slackerous Maximus
Garage door cables keep coming off.
One of the cables came off my garage door. This lead to hours of me avoiding tensioning the spring, and much swearing. Finally this morning, I bucked up my courage, released the spring and started from scratch.
I got both cables set up with equal tension, tensioned the spring, and opened the door. BOTH cables came off on the spot. How can this be? Am I wrong in thinking that cable alignment is critical here? When I reset the drums last night, I didn't pay much attention to where I put them on the shaft. Given that the cable is supposed to roll up precisely on the drum, the drums position on the shaft has to be correct so that the cable doesn't slip out of the groves on the drum and lose tension, yes? I'm about 10 minutes from calling someone and writing a check. I hate dealing with garage doors.....
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
1980 911 SC
After much swearing , up and down on a step stool 100 times, and a buckled garage door I finally called someone and wrote the check. I love my new garage door. Air tight and quiet.
Life's a Beach |
The Unsettler
One of the few things I'll not think twice about.
Write the check. |
Slackerous Maximus
Fixed it. I was right. Cable tension is important, but cable alignment is also critical. The cable has to roll up on that drum perfectly. It can be un-nerving tensioning the spring, but I took the time to go get a couple large eye bolts that fit perfectly in the holes on the tesioning colar. Boo ya!
Slackerous Maximus
PS: I promise to dig this thread up tomorrow when the door breaks loose and comes down on the hood of my 997
Platinum Member
Paper Member
Yeah, I went to Lowe's and bought a couple long steel rods (18") to adjust the tension on my door.
Enemy of the State Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it. |
Cars & Coffee Killer
Side springs?
The bearings in your pulleys might be bad too.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
