Nothing would kill an entire yard of grass to the last leaf but chemicals.
Dont get along with the neighbors do you...
How much area is being prepped and hydroseeded for 6k? I used to work for a hydroseeding company and that sound like a lot of money for the area in the picture.
Also don't get too caught up in the hydroseeding hype, unless you are doing steep slopes with special materials there isn't much to it. For the most part they mix grass seed, fertilizer, and water then it is covered with natural straw using a straw blower. Don't let anyone convince you to use hydromulch instead of straw, it looks neat because it comes out green but ours was just ground up newspaper and it doesn't hold moisture as well as natural straw. Natural straw will always yield a better stand of grass than hydromulch. |
If I was in your shoes hydroseeding would not be considered, unless you really don't like having money. Your climate and this time of the year mean the REAL ADVANTAGES (sorry weekend green thumbs) of hydroseeding won't benefit you.
My professional advice (though I'm not familiar with your soil): Rent a slit seeder or a power rake, a spreader (if you don't already have one), and a lawn roller. Buy top quality seed, 50# for your .5 acre is ok for your first app. Buy 10-10-10 or 12-12-12 or whatever you find and apply @ half rate, don't buy starter fert until next spring. If it was a mis-application of a product that fuched your grass the soil disturbing properties of the slit seeder or power rake (on a deeper setting) will be necessary, but you need to get the seed touching soil anyway and these tools are great. Make sure you don't allow your fert company back, this year or next spring. The products they apply during these times of year in a typical fert program will kill your new grass, if somebody tells you that a pre-em product next spring won't hurt grass started this fall they are WRONG. In fact from what I saw in the before pic don't have them back at all. You can get much better results using common sense and some simple products, just tune out seasonal marketing hype and misinformation from friends/well-meaning pelicans. Keep your grass as long as possible (my mower has 6 height notches, I always have it in the highest setting) except during wet summers/warm nights/evidence of fungal activity. Hope this helps! |
....."I am thinking about laying some irrigation down prior to trying the repair".....
I think this is the most important thing that you could do, especially now that your lawn is non-existent. |
And with a little help from friends (for the math and design, install for 18ksf as depicted in your photos would be an easy job for one guy) you could have a system superior to anything a 'professional' irrigation contractor would install. The wind you're concerned about is going to dry out the hydroseed mulch just as quickly, well just slow enough so that your seed can still germinate, then die when it dries up because the seed hasn't made contact with the soil, just the hydro mulch. Without hydro mulch the seed is either going to magically levitate or touch the soil (THIS IS KEY, that is why I mentioned the lawn roller and scarification equipment). One mistake contractors and homeowners both make is being a cheap ass when it comes to seed. Sticker shock and lack of basic math skills has folks coming home with inferior varieties and insufficient quantities. Don't be that guy. |
Aw hell, jump off yer wallet and sod the entire thing. You can always take out a second on the house ... ;)
I don't know but as an NFA grad I salute your choice of locale. :-)
He's the guy who said Quote:
Oh wait never mind, he was only the assistant groundskeeper. Had a lot of stuff on back order, credit trouble ..... ya know |
Tractor Supply had 50# of grass seed on sale for $39.95 last week. They have 10 stores in CT: Tractor Supply Company - Generic Error
Get a tractor in to cut down the hill. Put a sprinkler system in. Layer seed (3 layers). Put up some wind deflectors so the topsoil doesn't blow away over the winter. They stop the straw being blowen away too. Fire lawn company. They ultimately caused the grass to die. Lawn cut too short, heat stressed, then burnt with fertilizing. Newly seeded lawns need lots of water. |
My (small) lawn
All I use is Ringer's Lawn Restore, which is an organic fertilizer, once in the spring and once in the fall. I didn't even water the lawn this summer, we had so much rain...
http://forums.pelicanparts.com/uploa...1319336300.jpg |
Here is what they use around here. Problem solved, no more watering, mowing or fertilizing needed. :D
OK an update. Since the whole thing was ruined I had irrigation put in. Nine zones, yikes! There also is a wireless rain sensor for the roof. Pretty cool stuff actually. The ground was power racked and leveled back out. A bit of topsoil in low spots. Supposed to be hydroseeded tomorrow. Today... http://forums.pelicanparts.com/uploa...1336523962.jpg So there went the repair money for the Porsche, (the lawn and knee surgery for my girl cattledog). I just couldn't stand looking at that mess anymore. |
Markus,
Thanks for the update.....looking good. I've already replaced a few yards around here involving new wells, pumps, irrigation systems, plants, sod, etc. We don't really use seed too much - just sod. Tell us more about the ACL surgery on your furkid? Billabong is still in rehab with hers (left rear). Here's a yard I did not long ago.... Before: http://forums.pelicanparts.com/uploa...1336524961.jpg After: http://forums.pelicanparts.com/uploa...1336524996.jpg |
| All times are GMT -8. The time now is 11:32 PM. |
