Go Back   Pelican Parts Technical BBS > 5 - Miscellaneous > Off Topic Discussions
Family Values
KaptKaos's Avatar
Wireless router with range to cover 4500 sq ft house
I have a project that needs a good wireless router to cover a large home.
Any recommendations?
- Joe
Necessity is the plea for every infringement of human freedom. It is the argument of tyrants; it is the creed of slaves. - William Pitt
Old 10-18-2011, 09:40 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
id10t's Avatar
Run extra wires and have multiple access points. Or get repeaters.
Old 10-18-2011, 09:48 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
spinner's Avatar
Any of the newer N routers centrally located (not basement) should be fine. I have a similar sized home and my (older) D-Link DIR-655 Extreme N router works great.
Old 10-18-2011, 09:49 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Canada's favorite
RANDY P's Avatar
I installed a cheap N router in a 30K sq foot concrete BOWLING ALLEY and had good wi-fi in every seat.
rjp
QUOTE: NOTA, on dating: I have a simple system-I ask them to put it in
--if they donot it don't go in
Old 10-18-2011, 10:23 AM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Just about any router would probably do it, but specifics of the building may make certain areas worse than others. There is a certain room in my house that almost seems like it is shielded in one corner. Options to improve coverage would be a better antenna, or running a cable from the router to move the antenna to a better location. Another option is like what was mentioned earlier, multiple APs.
Old 10-18-2011, 10:37 AM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
mikester's Avatar
Send a message via AIM to mikester
I can't believe you didn't ask me first - I thought we had something special.
4500 sq ft with walls and what not isn't going to be a challenge for any consumer class access point or wireless router.
they are limited to transmitting at less than 100mw and typically try to do so at under 75mw (so that they don't have to provide higher grade internals and can avoid using a fan because fan noise is bad).
The best bet I have done is a Linksys WAP-54G with an 'aftermarket' kernel loaded on it. Linksys doesn't actually make these anymore to my knowledge. You can find them on eBay and with the aftermarket kernel you can up the transmit values towards 80mw. This is how I got good coverage in my house.
You do need to elaborate though - is it a 4500 sqft house or is it just 4500 sq ft with some of that being house and some of that being the rest of the property.
My property is about 4500 sq ft and I do get wireless outside but it isn't great in my front or back yards. Side is okay but I don't really use it much out there. I use a Cisco 871 SOHO router which is a B/G radio. Probably not what you're looking for; I think your best bet is to see what AP/WRT the kidz these days are hacking and check it out to see what the hacks enable you to do.
Failing that - run some wires and drop more than one AP - you'll be glad you did.
-The Mikester
I heart Boobies
Old 10-18-2011, 01:56 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
woodman's Avatar
And i can't believe you don't know the answer already...why don't you ask your IT guy dood.
'75 1.8 -->1911
Old 10-18-2011, 02:16 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
Slackerous Maximus
HardDrive's Avatar
2004 Royal Enfield Bullet, dripin' oil like an old flat six.
1992 Ducati Supersport. White frame, Ferracci pipes, open airbox.
Mercedes E350 family truckster.
2003 Mustang Mach 1 with Cherry Bomb exhaust
Old 10-18-2011, 02:36 PM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
Cars & Coffee Killer
legion's Avatar
I have multiple access points. An added bonus is that wireless traffic is much faster as I have fewer devices attached to each access point (less sharing of wireless bandwidth).
5 liters of VVT fury now
-Chris
Old 10-18-2011, 02:56 PM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
Family Values
KaptKaos's Avatar
Thanks Mike. I prolly will call you.
It's a huge house in Beverly Hills. It's old, and three stories and has thick walls. There's a lot of outside space too.
There's an Apple Airport there on the 2nd floor now and it sucks. I think there is a repeater on the lower level, but I am not sure how it is connected.
I need to get back there.
Oh yeah - @Woodman - pfft!!
- Joe
Old 10-18-2011, 05:19 PM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
slodave's Avatar
I did a 3 story building (thick walls) in Venice 3 years ago with higher end AP's running POE. Coverage actually overlaps between floors and probably exceeds 4500 sq ft. POE worked out really well, since getting power to them was not easy.
Old 10-18-2011, 05:30 PM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
canna change law physics
red-beard's Avatar
+1 or really, maybe +3 or 4
James
Red-beard for President, 2020
Old 10-18-2011, 06:29 PM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
If you have something as a router (any wired one will do), get a 3 pack of these:
UniFi-AP-3 (3-Pack)-US - UniFi AP, 3-Pack USA
Or maybe try one of the -LR (long range) and add a 2nd one if you need one.
I have 5 in an 8500sqft commercial building. 3 Were covering it just fine, but we wanted to add the back stairs and double up on one area.
I have one of their really small APs at home and get good signal from the opposite side of the house, which is~50' and 4 walls.
Rob
1980 SC
2002 M3
2011 Tiguan
Old 10-18-2011, 06:44 PM
  Pelican Parts Technical Article Directory    Reply With Quote #13 (permalink)
Or actually, if you can get it right in the middle, one of these may work fine:
PowerAPN-US - Indoor 802.11n Access Point USA
I picked up one for someone else at work, and he has it on one end of a 5k sqft house and it works great.
Rob
1980 SC
2002 M3
2011 Tiguan
Old 10-18-2011, 06:46 PM
  Pelican Parts Technical Article Directory    Reply With Quote #14 (permalink)
Insert Tag Line HERE.....
rattlsnak's Avatar
I just upgraded to the new Cisco / Linksys. Linksys E4200 - Maximum Performance Wireless N Router - Cisco Home Products Store
I have a 3900 sq ft house and this router rocks... Full movie/tunes streaming from multiple devices all over the house...
Old 10-18-2011, 08:17 PM
  Pelican Parts Technical Article Directory    Reply With Quote #15 (permalink)
The Mighty Pieholio
Bob Kontak's Avatar
+1
I have the legacy N version of this router. No need for a repeater.
Old 10-18-2011, 08:25 PM
  Pelican Parts Technical Article Directory    Reply With Quote #16 (permalink)
Bland
RWebb's Avatar
does the house have a stone or brick chimney in the middle of it?
Old 10-18-2011, 10:01 PM
  Pelican Parts Technical Article Directory    Reply With Quote #17 (permalink)
fuelie600's Avatar
+1 on the DIR-655. Very happy with mine.
I will never do linksys again. I had 2 WAP-54G's die after 4-5 months use on each.
Evan
1987 sun roof coupe
Old 10-19-2011, 07:37 AM
  Pelican Parts Technical Article Directory    Reply With Quote #18 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
