Alright. Still no power since Saturday's storm.
I have a detached garage, with garage door openers. The only way in and out is via the garage doors. The garage is holding my car hostage. I have a portable generator. I'd like to provide power to the line going to the garage so I can get the door open. The problem is the only place I can find to tap into is the light switch in my house that controls power to the garage (yeah, I know, its scary - house is from the 1920's). This light switch has only two wires on it, white and black. I assume this switch provides continuity across these two wires. My guess is that maybe this switch is in series with the hot (or maybe even neutral?) lead? If so, how do I hook my generator up to this? Is it even possible? I was really hoping to crack it open and find 4 wires in there . . . . Any help is much appreciated! Thanks, Stranded in NJ. |
The Unsettler
Assume the only way into the garage is the garage door?
No side door or window?
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Student of the obvious
Lee |
No side door. Plan "B" is to break one of the window panes. I was hoping to find a non-destructive alternative if possible.
After this, I'm going to run a cord to one of the openers such that I can get to it from the outside . . . . I'm also frustrated because I bought a opener w/ battery backup for just this eventuality, but that is not working either.
Banned
pull the cord by the power box/light, it unhooks the chain, then pull the door open.
Ooooh - Lee. Nice one - let me see if I can reach that. I even have a wire-snake too!
do what the pro thieves do. break a garage door window and use a hook to yank on the pull cord. does the roll up door have windows?
poof! gone |
Platinum Member
The switch sounds like a leg. Powering the 2 wires of a leg won't do anything unless you can catch the neutral. Now, if the box has a ground or is grounded, you might get the garage powered up by powering up the power leg of the switch and attaching your neutral to the box or ground. Install an exterior outlet once this is over to ensure you can power the garage in the future by backfeeding the outlet. |
If the "shimmy a wire and release the door trick" doesn't work, I suggest you do the following:
1. Throw the main power circuit. You don't want to be doing this and all of a sudden your power comes back on! 2. Take apart the switch in your house that turns power on to your garage. Try to trace the wires and determine which ones are going to your garage. 3. Grab a car battery and connect the white wire to + and the black wire to -. 4. Hit the remote opener. The car battery should have enough power to get the door opened -- at least just enough for you to crawl under the door and pull the manual release. Of course, if the only car battery you have available is the one that's in your car, that doesn't help a whole lot. Also - the car battery is less likely to have sufficient power to kill you or do severe damage to your home's electrical system should something go wrong. A gererator, on the other hand, might. -Z-man.
2010 Cayman S - 12-2020 - 2014 MINI Cooper S Coupe - 05-17 - 05-21 1989 944S2 - 06-01 - 01-14 Carpe Viam. <>< |
abides.
I'd backfeed through the socket for your clothes dryer. Be sure to disconnect from the grid, as Z-man says above, so you don't kill any linemen working on the power lines nearby. Dunno how big your house and generator are, but it would probably help to flip off any unneccesary breakers while doing this.
This is not the proper way to connect a backup generator, so don't get in the habit of doing this.
Graham 1984 Carrera Targa |
Forgot about one thing with the battery trick - car batteries are DC, not AC.
So... Find a fellow with a large SUV that has a DC to AC inverter built into the truck. Plug an extension chord into the AC power outlet in the truck. Now carefully take the wires from the house switch that powers your garage and slice them into the extension chord. Now, you should have sufficient power to raise the door. Of course, by now, I'm hoping that you have power back! -Z-man.
I'm alive, and have my car. I did it the old fashioned way (I eventually got in through the window).
To follow up, I have thrown our main breaker, and all other breakers, before fiddling with the generator. I am aware it could affect the linesmen and even myself / family. So far I have heat and internet. I was able to disconnect the 110 supply to my furnace, and splice in an extension cord. So nothing is being back-fed into the house. I feel better having made some progress. The yard, on the other hand, is a complete mess - but the family is safe and warm, so that is all that matters. I don't expect power for a few more days. |
