There seem to be a plethora of gun experts here so I figured I would ask...
I have a Kimber 1911 Custom. The gun is SOOOO tight that it only likes one brand of ammo. It jams occasionally and therefore sits in the safe, unless I want to go the range. (ie it is not what i have in the night stand for protection. (that is my lowly Ruger KP90 that has NEVER jammed once in over 2000 rounds of every brand of ammo). Anyway, here are my questions: What could be the problem? Are there are any recommended gunsmiths for Kimbers in Orlando? Are all Kimbers this tight and finicky? Thanks! t.
tk 08 911 C2S - Sold 13 Audi A4 14 Jeep SRT 500HP |
Gon fix it with me hammer
I have a brand new Dan Wesson PM7.. Very tight as well.
Haven't really tried any other ammo but the Fiocci .45 ball i bought... And only had 3 jams I only have the jams when the gun warms up. Basically i get a failure to go to battery.. what happens is the oil/grease warms up, and the action cycles faster then when cold. And i was using cheap magazines as well as the Dan Wesson (chip McCormick) mags. The jams only happened with the cheap MecGar mags, not with the DW mags. with the DW mags i never have any jams whatsoever.. And i've shot about 500 rounds this last month. So the question is.. What mags do you use, and what kind of a jam are we talking about? Make sure you get good mags, Chip McCormic powermags, or as others told me Wilson Combat But, see what the others say, i'm a relative newbie myself, the DW is my first gun.. only had it a month.
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
'95 993 C4 Cabriolet Bunch of motorcycles |
Springs for COLT 1911 GOV'T PISTOL Semi-Auto Pistols if its a 5 inch barrel then you can can change out the recoil and magazine springs with colt springs on this sight. I had the same problem this cured it. also I oiled it liberally until it broke in. Change every SPRING out with aftermarket ones...
76' 911s Signature Edition |
19 years and 17k posts...
I would take it to a local, competent gunsmith (research this 1st). There are many things that can be done, but start with the least invasive and then test thoroughly after each modification. I have found that quality magazines and springs takes care of 95% or more of these kinds of issues...
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
How many rounds do you have through this gun? They can take some breaking in. I'd want a few hundred rounds through it before I started replacing stuff.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
the 2 guys above know a LOT more about guns than I do.... what I posted is what I did with my particular gun and situation....also I ended up with a 18.5 lb recoil spring out of the "calibration" pack
76' 911s Signature Edition Last edited by enzo1; 11-06-2011 at 09:16 AM.. |
Evolved
QUOTE: "It jams occasionally.."
_________________ First define for us - "jams?" Fails to feed? Fails to extract? Fails to completely eject (smokestacks)? Fails to go completely into battery? more info needed....
Don't fear the reaper. |
Wow, great follow up questions.
So, this is what I have experienced. The non Kimber clips jam regularly. The Kimber ones, much less often. I get a couple of things defined as a jam. One, the empty case gets stuck sideways when being ejected. Two, the slide doesn't lock back when the last round is fired (not a jam, just another symptom). Three, I pull the trigger, and the round is not fired. What I do: 1. Clear the round and cycle the slide. 2. Pull the slide, validate the gun is empty and manually lock it back. 3. Pull the slide a couple of times and have a couple of rounds get ejected. The gun has had well over 1000 rounds though it. It is SOOOO tight, and re-assembly is a nightmare. The spring is so strong. Hopefully this helps. I can post pics if necessary. How do I know if the feed ramp is in good shape, or worn? Thanks again! t.
"Round is not fired"
is the gun in full battery? Does the hammer at fall or not?
Something's not right, fix it or sell it. It should not be that fussy, but then I don't own any Kimber pistols.
Jim
down to jap bikes that run and a dead Norton |
I would definitely take it to a good, local gunsmith to have it inspected to see what's wrong. You could send it back to Kimber, but that's not what I would do 1st, I'd get it to a gunsmith 1st.
I would send it back to Kimber. I've heard they have good cust. service and are used to fixing their guns because they have horrible quality control. Shouldn't cost you a dime.
BTW, what kind of ammo are you using? I'd be sure the last 100 rounds I put through it were 230 gr. FMJ factory loads so as to not have any warranty issues.
The hammer does fall, but no round is fired.
Not sure what full battery means. If that means, is the round fully in the chamber, yes.....scares the crap out of me when I clear it. If it means, if the magazine is full..then it varies. The brands of ammo have always been standard brands (nothing like Wolf ammo, but Winchester, Federal (i think), etc). No +P rounds or anything either. The one round is does well with is Fittupucci or something like that. So, does anyone know of a good gunsmith in central florida? I have thought about sending it to Kimber, but would like to know a recommended smith in the area anyway. Thanks again for all the info. Pelican is an awesome resource once again. t
I'm with Bill
I don't have an answer for your question but I am glad to see I am not the only person who likes his P90
Electrical problems on a pick-up will do that to a guy- 1990C4S |
Double Trouble
send it back..
B58/732
FWIW, I hate Kimber (Yonkers Kimber...when they were in Clackamas they made outstanding guns) and will never own another.
ΜΟΛΩΝ ΛΑΒΕ I don't always talk to vegetarians--but when I do, it's with a mouthful of bacon. |
If it is a stainless steel 1911? Stainless steel binds. So the slide can jam up and oil doesn't help. Try cleaning out the oil and spraying it with a good quality silcon spray then try it at the range. It will appear dry but that doesn't matter, this simple "fix" may cure your problem with minimum of drama.
I'd still demand Kimber make it right. If you want to start throwing money at it, you can mail it to Robar and have them refinish it in NP3, which is very slick due to the teflon content. It looks amazing. Eric Coffey had his Kimber redone in NP3 and it looks awesome. Definitely loosens things up as far as binding goes, but you shouldn't have to do that.
