-   -   Gateway desktop is dead, any help? (http://forums.pelicanparts.com/off-topic-discussions/645253-gateway-desktop-dead-any-help.html)
LakeCleElum 12-17-2011 07:31 AM
Very simple DIY project. Once the cover is off, it's just 2 or 3 minutes. Test output voltage 1st.
Hugh R 12-20-2011 05:02 PM
$69.99 and I'm up and running. Thanks guys!
Joeaksa 12-20-2011 05:08 PM
Originally Posted by Joe Bob (Post 6436477)
Power Supply....I'd pull the hard drive and copy it to save your data.....but that's just me.
Same here, had it happen a couple of times...
GWN7 12-20-2011 05:11 PM
So what was it?
I voted power supply too.
Hugh R 12-20-2011 05:51 PM
Power supply. Surprisingly, the puter seems to run quieter as well.
syncroid 12-20-2011 05:58 PM
Good for you Hugh. You got luckier then I. When my power supply died, it took out my mobo. :mad:
stomachmonkey 12-20-2011 06:23 PM
Possible, could be a better quality power supply with a better fan.
azasadny 12-21-2011 07:52 AM
Sometimes the failing power supply can take out the systemboard and you may see leaking capacitators. This just happened to an old PC that I was repairing for a friend.
