Professional Bull5hiter
Outback Porsche's Avatar
Packaging Engineers
These wankers are making it harder and harder to put these ICs on without expensive equipment.
It took a bit but I finally worked out a way to get these buggers on by hand soldering. This pic is magnified x40 and I've got to work under a microscope to do it. No wonder my eyesight is failing....
Jeff
83 944 Guards Red
23 718 GT Silver
Old 12-21-2011, 08:02 PM
Whoopsies I was banned!!!
Esel Mann's Avatar
Yeah,
Amazing isn't it!
Long gone are the days of using a simple soldering iron. Now one needs a hot air reflow setup minimum. It's good for the small parts but then there are the high pin count fine-pitch BGAs which, trying to do those manually with a simple hot air reflow is almost impossible without a high fall-out. SOA BGA hot-air reflow stations require selling both your nuts plus a nut from someone else.
Old 12-22-2011, 08:43 AM
vash's Avatar
packaging engineer? i thought a pack eng builds those damn plastic containers that are damn near impossible to open?
poof! gone
Old 12-22-2011, 09:04 AM
How did you do it with an iron?
EDIT: I see. the pads extend beyond the part. Tin the pads, balls and apply pressure.
Rick
88 Cab
Old 12-22-2011, 09:08 AM
Rob Channell's Avatar
Our techs use some sort of hot air device. It's probably expensive.
I'll bet you could makeshift something smaller using a hot air gun designed for heat shrink tubing. It has a slower airflow and hotter temps than a hair dryer. Then you make some metal adapter tips for the end to shape the airflow for the size and shape chip you are doing. Perhaps a laser temp gauge would let you know when you got the right temps without exceeding the chip limits.
Rob Channell
One Way Motorsports
1979 911SC mostly stock
1972 911T Targa now with a good 2.7
1990 Miata (cheap 'n easy)
1993 C1500 Silverado (parts getter)
Old 12-22-2011, 01:29 PM
jluetjen's Avatar
What is that? A 3x3? Be happy it wasn't a bumped die!
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 12-22-2011, 02:17 PM
How much for the tintype of the cow with buck teeth?
Jim
down to jap bikes that run and a dead Norton
Old 12-22-2011, 03:41 PM
It's a whopping 4x4 LGA package! I did the pcb design, so I've only myself to blame for it being there. I had some other bonehead do the assembly, but he cooked this device good and proper (and a few others). The pic is after I removed the dead device.
Like most things, to get them on it's all in the prep work. Clean between each step and use plenty of flux. Soldering iron used to 'bump' the pads on the package with solder, and localised hot air on both sides of the pcb to 'reflow' it back on. If you can get the position close (hence the microscope), these devices tend to self locate when the solder flows. This pcb's a prototype, so I designed the land pattern so that I could get it on manually. It'll be a slightly different land pattern for an automated process (if it goes that far). It's also a multilayer pcb with most of the internals being heat robbing copper planes - doesn't help the manual assembly process.
Manual hot air assembly devices are relatively cheap in comparison to mini reflow/IR ovens and paste machines.
Jeff
83 944 Guards Red
23 718 GT Silver
Old 12-22-2011, 08:44 PM
Jim
Hehe...I didn't see it at first. Well spotted
Jeff
83 944 Guards Red
23 718 GT Silver
Old 12-22-2011, 08:50 PM
Aren't they also a pain in the bum. I always end up cutting myself on that stuff
Jeff
83 944 Guards Red
23 718 GT Silver
Old 12-22-2011, 08:52 PM
Originally Posted by Esel Mann View Post
Yeah,
Amazing isn't it!
Yep. I have to send anything I design with BGA's away for assembly and x-ray inspection.
Jeff
83 944 Guards Red
23 718 GT Silver
Old 12-22-2011, 08:57 PM
