-   -   series circuit questions (http://forums.pelicanparts.com/off-topic-discussions/646369-series-circuit-questions.html)
rick-l 12-22-2011 11:55 AM
How about this guess? The battery conceals three oscillators. The switches contain a band reject filter each set to a different frequency i.e. it passes everything that is not in band. The LEDs contain a bandpass set to their respective frequency that goes to the lights.
But I sure don't see all that hardware
Flieger 12-22-2011 04:54 PM
Gee, how did you come up with that?
Originally Posted by 9dreizig (Post 6447504)
Each LED has a tiny inductor (L) and capacitor (C) across it. Each LC pair is tuned to a different frequency. The LC is a short at DC, but at f1, f2, f3, go high impedance and allow current through the corresponding LED. The switches have a resistor (R) and capacitor (C) in parallel across them. The C large enough to allow f1, f2, f3 through, and 3 different values for R. The battery has 3 oscillators, each of which is enabled depending on the DC current value - set by switches.
Originally Posted by 9dreizig (Post 6447507)
that was a quote from the youtube uploader
Originally Posted by Flieger (Post 6447869)
I do.
Basically it is a trick. The battery is not putting out DC, but three different frequencies due to the crystal oscillators. The switches each act as a filter to cut off a frequency. The LEDs are tuned to resonate (light up) at a certain frequency, so depending on the switches' positions, different frequencies reach the LEDs and only the LED that is tuned for a certain frequency will light up. Any other frequencies will not cause it to light up, unless the resonant frequency is also coming in (since you can superimpose frequencies).
This is mostly a demonstration of the cool things you can do with resonance.
lane912 01-30-2012 10:48 AM
so here is how he did this
Solution - series circuit 3 LEDs - YouTube
<iframe width="420" height="315" src="http://www.youtube.com/embed/mzDTZuFJYX4" frameborder="0" allowfullscreen></iframe>
