The Unsettler
Home theatre wiring
Finally getting around to dealing with my media room upstairs.
Had the room wired 7.1 Installers also ran coax for my component to the projector. Have a built in media cabinet where everything starts. First thing I'd like to do is put a wall plate in the cabinet so I dont have a mass/mess of wires coming out of the wall to the receiver. Something like this. ![]() I would do similar two wire plates for the speaker locations. I also need various ends and assorted connectors. Was at Lowes today picking up some other stuff and priced the items out there, was around $200 just for wall plates. So what I need help with is a good cheap source for this type of stuff.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Rob 1980 SC - 2011 Tiguan - 2018 Tesla M3P |
David Dryden '86 911 Coupe '05 BMW X5 4.4i |
The Unsettler
Same speaker wall plates for $1.96 that Lowes wants $13.99 for. Thanks,
Put a central patch panel in somewhere else - go ahead and add ethernet and phone (2 or 3 runs of cat5) while you are at it. Have power available where the patch panel is. Actually, after a quick google it seems that running your a/v stuff over cat-5 (in teh walls) w/ appropriate connections at each end is entirely possible...
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
Garage Queen
Just curious, what other cables you are running to your projector beside coax? We a home theater with projector and it was difficult to find wall mounts/outlets for the HDMI cables. In fact, it was so difficult, we ended up running long/very long HDMI cables from projector straight to components.
Stephanie '21 Model S Plaid, '21 Model 3 Performance '13 Focus ST, Off to a new home: '16 Focus RS,'86 911 Targa 3.4, '87 930, '05 Lotus Elise, '19 Audi RS3, |
Formerly reformed
Picked up my banana plugs and related hardware on Amazon. Works great. Just don't stoop for the ridiculously cheap items.
On Q plates from Lowes were also pretty reasonable if you buy in bulk.
1968 911P (Paperweight) |
The Unsettler
I'm all for keeping things neet and tidy, but your best audio connections are the ones with the least amount of connectors. If you plan where your plates will be, they will generally be hidden behind the audio equipment. Likewise with the speakers. There is not much cleaner then a 1/4"hole close to the speaker mount with the wire coming directly out and into the speaker. Some mounts allow you to bring the wire within it. You can adjust the length by pushing the wire back into the wall. I've wired 2 systems in my home this way, not because I'm cheap (well, maybe), but I wanted the cleanest, most uninterrupted runs possible.
I recently set up my basement as a media room with everything ran in the walls. Was going the same route with the connectors then realized it is not a great idea. Instead of a speaker wire having 2 terminations, they now would have 6 each.
I ended up using standard blank plates with a hole drilled in the middle to match wire size. Nice clean install with no breaks in the wires. |
I did the same as above. Less connections = less signal loss = better.
I also ran a long HDMI. It rocks! Larry |
