230% efficent light source
well no laws were broken either-
Ultra-efficient LED puts out more power than is pumped in (Wired UK) ideas? |
This should be good. First in.
Hook it up to a generator and we could rule the world!
Or better yet shine it on a solar panel! Edit to add. read the article... looks pretty cool. |
fixed it for ya |
what if you made electrons from the extra photons and feed it back to the light emitting device you are making electrons from?
will this take the power away from oil?
woooo defying the laws of thermodynamics!
all u need now is 1 of those bulbs and hook it up to a solar panel and back to itself. free energy from nothing! |
On the flip side, they would probably make the ideal fridge light. |
It depends on the wavelength. If we use the wavelength where the human eye has maximum sensitivity, 555 nm (yellow green), then 1 W = 683 lm. That's 1.464 x 10^9 picowatts per lumen.
At 69 picowatts per LED you would need around 21 million of them to give you a lumen! |
interesting -- I've been wanting to replace the Dometic fridge in my VW Westy and now...
Parking lot LEDs |
and the commercial/industrial platform of this would need reverse heatsinks.
thing is could you pair a regular LED and a uberLED together so that the uberLED IS the heatsink for the regular LED. how much heat wattage draw can you create. |
Perfect light for a refrigerator, it cools down the surrounding area, right?
ask yourself how many semi-conductor devices are on a current Intel CPU, a memory chip, or an LED TV screen and then Google Shockley and the first one made... |
Oh come on. My comment was in jest.
It is interesting theory at this point but I can't imagine it will be used as a light source in the home in the near future. It may have some applications someday but not as a replacement for the light bulb. |
LEDs are now being produced on a single chip the size of a standard CPU. what looks like a single square of light is in fact hundreds or thousands of individual emitters packed into a square inch and a half or so-
| All times are GMT -8. The time now is 09:47 AM. |
