-   -   How can I use a subwoofer with my PC speakers? (http://forums.pelicanparts.com/off-topic-discussions/669224-how-can-i-use-subwoofer-my-pc-speakers.html)
willtel 04-01-2012 07:37 PM
I'm using a little class T amp to drive some bookshelf speakers off of a Mac mini. I just split the mini-jack connector into two RCA's and run it into the amp then out to the speakers.
The back of the amp looks like this:
http://p.lefux.com/61/20100220/A1772...plifier_18.jpg
It sounds decent but it could use some low end. I also have a weird old Kenwood subwoofer that I would like to add to the system. It is powered and has a single RCA as an input.
It looks like this:
http://i1.lelong.com.my/UserImages/I.../kuewwai@5.jpg
How can I add my existing sub to the system on the cheap?
rick-l 04-01-2012 08:21 PM
The Kenwood manual says you are supposed to use the "supplied adapter" which is probably a filter.
willtel 04-02-2012 05:01 AM
Ahh. I see that now. I bought this thing used a decade ago so I didn't get the adapter. Does anyone know of something aftermarket that would do the same thing?
http://i.imgur.com/xAs3p.jpg
jpk 04-02-2012 05:51 AM
You could use something like this to replace the "adapter"
Amazon.com: Planet Audio PEQ10 4 Band Graphic Equalizer Subwoofer Output with Adjustable Crossover: Car Electronics
