Quick baseboard + laminate floor question
I have a small section of wall that is a little off-kilter from the rest; it's between two doors, and there's a bit more of a gap between the flooring and the walling thatn everywhere else. Should I handle this with a wider baseboard, or should I cut a super-thin piece of laminate and try to slip it in there?
http://forums.pelicanparts.com/uploa...1335389776.jpg http://forums.pelicanparts.com/uploa...1335389805.jpg |
I would go with the wider baseboard. It's fairly common o leave a small gap for expansion.
thick baseboard
I'd go thick baseboard. If you do decide to place a thin piece of laminate, place it along side the wall and place your pencil in a metal washer and roll along the wall as you scribe/ mark the laminate. This will reproduce the uneveness of the wall onto your workpiece.
Certainly a wider baseboard is easier.
But, are you replacing all baseboard? If you have a wider section that differs from other walls, will it be obvious? Maybe the super-slim piece makes the rest of your project go a little better? Knowing what you've told me, I'd prob go with the super-slim piece. |
Baseboard plus a baseshoe is the classic way.
1/4 round and shoe mold are different. Shoe is typically taller than it is wide. Shoe mold looks better in my opinion.
Thanks guys! If you ever have questions about SAN, LDOM, HPVM, ESX, Linux, HP-UX, Solaris, AIX, or networking, lemme know :)
Move the wall.
Baseboard + shoe - you'll never tell and it'll look clean.
Do it the right way and slice a piece of laminate.
Wider or furred base will make the base proud where it ties into the jamb casings. |
Shoe can be 1/2 x 3/8 or 3/4 x 1/2 with a very gentle round over, the radius being about 1/4.
I broke down and ripped a small strip to patch in. What a PITA! Cutting it was easy; getting it to click in was difficult.
http://forums.pelicanparts.com/uploa...1335494985.jpg |
I've heard 1/8" gap to the wall is correct for expansion, and easy to cover.
Also, use a flexible "Japanese" saw to cut the door mouldings up slightly so they don't restrict expansion. Lay the thing on a hard/thick slippery plastic surface to protect the floor. |
I've put on the baseboard, which would not have even come close to covering the gap; if you look close you can see the line between the two planks.
http://forums.pelicanparts.com/uploa...1337469375.jpg |
Was there a sale on brad nails, or do you simply enjoy using the nailer? :p
Otherwise, good job. The baseboard without shoe or quarter-round looks clean. Set the brads with a nailset. Putty and paint. |
Materials expand differently. Natural wood swells more across the grain than lengthwise. That expensive underlayment with a gap helps bubbles and pops in the tight, noticeable places. It's worth it to tape the seams well and pay a little more for something that let's the wood slide. As a caveate, a moisture barrier is only a bandaid and may make the material below(subflooring/joists) mold and rot. Moisture control is important as well: -Too little moisture during the winter (for us northerners), and huge shrinkage/gaps appear. -Too little moisture, and the gaps can clash, buckle and pop up in waves across the surface. |
| All times are GMT -8. The time now is 10:47 AM. |
