-   -   Rust Removal (http://forums.pelicanparts.com/off-topic-discussions/674306-rust-removal.html)
trekkor 04-26-2012 09:59 PM
Rust Removal
I have a small tile cleaning job tomorrow.
Heavy rust stains on some slate tile with a high level of quartz content.
I was thinking of an aggressive acid wash.
Anyone have a secret brew?
I'll post pictures of the before and after tomorrow night.
KT
ben parrish 04-27-2012 05:57 AM
A product called" Awesome" has worked well for me on rust stains...also..CLR.
gr8fl4porsche 04-27-2012 09:21 AM
We use CLR and a power washer (for exterior stains).
trekkor 04-27-2012 09:40 AM
Thanks for the power washer tip.
I have one.
client wanted me to tear out the stained tile and replace it.
I told them I thought I could give cleaning it a shot first.
KT
Zeke 04-27-2012 01:12 PM
The same stuff we use on cars would be worth a try, phosphoric acid.
azasadny 04-27-2012 03:23 PM
Diluted muriatic acid has wirked for me. Be careful!!!
Worked not "wirked" ... I hate this Iphone
A930Rocket 04-27-2012 03:39 PM
Is the iron on top or impregnated in the slate? If impregnated in the slate, is this something that would have to be done every so often?
If on top, what caused it?
trekkor 04-27-2012 03:59 PM
Here's the results:
Before:
http://i944.photobucket.com/albums/a...s/P1140307.jpg
http://i944.photobucket.com/albums/a...s/P1140308.jpg
http://i944.photobucket.com/albums/a...s/P1140309.jpg
After:
http://i944.photobucket.com/albums/a...s/P1140310.jpg
http://i944.photobucket.com/albums/a...s/P1140311.jpg
http://i944.photobucket.com/albums/a...s/P1140312.jpg
I used the equivelent of CLR, "ZEP" rust remover mixed at a 50/50 dilution.
I used a stiff bristle deck brush and rinsed thoroughly.
Took about 30 minutes, including dry time.
I had muriatic in the truck as "back-up" but never needed it.
KT
Zeke 04-27-2012 04:02 PM
You just made one happy customer. I guess you will seal it.
How are you at marble? ;):D
trekkor 04-27-2012 04:04 PM
There is a drain tube the exits the house above the patio from an A/C unit or something.
The rust came from that and is all down the side of the house, too.
KT
trekkor 04-27-2012 04:06 PM
I was thinking about trying some muriatic acid on a spare piece of white marble I have to experiment with surface etching...
KT
porsche4life 04-27-2012 04:26 PM
^^^^ I bet that foams up big time.
john70t 04-27-2012 04:42 PM
Originally Posted by trekkor (Post 6716002)
There is a drain tube the exits the house above the patio...KT
Drain tube directly above doorway. Interesting.
johnco 04-27-2012 04:48 PM
be careful with the muriatic acid. all it takes is a little splash to customize your cornea.
btdt
http://forums.pelicanparts.com/uploa...1335570481.jpg
