First scope you ask? A 6" or 8" Dobsonian is the answer. You can find them relatively inexpensive on craigslist, etc.
Going this route allows for easy transport to the back yard or observing site. They have no electronics to mess with, no wires, just a simple design for up/down and left/right adjustment by hand. They usually come supplied with 2 to 3 eyepieces for changing magnification. Start with the largest number on the eyepiece, probably 24mm or 28 or 30mm. This gives the widest field of view and allows you to find objects easier. Once you've found an object and want a higher magnification switch to the medium eyepiece, 10-16mm. Want even higher mag, put in the smallest eyepiece. Sometimes (most) you will find the medium and low power eyepieces have the best view. This setup will give you lots to look at in the sky and let you know if you even want to pursue the hobby further without loosing a bunch of $$$. You can easily sell it for what you paid if you bought it used. |
eyepieces vary a lot
most cheap zooms suck microscope ones will work old busted binock's eyepiece can be used better ones cost more star partys are a good way to see what other have/use |
One of the keys is quality. I get amazing views out of my 8x42 Nikon Monarchs. I recently got some Vortex Viper HD 12x50 for looking at birds around the property which are also excellent. Very commonly recommended are 7x35, 8x42, or 10x50. The two lower magnification are probably better for being able to see detail if you're holding them by hand. One point I'd like to make is that you should have an understanding of what you can see in your area (light pollution) with various tools. A lot of times astronomy clubs have "outreach" nights where a bunch of folks setup scopes in more accessible areas and let the public come look through things. You may want to reach out to a local club so you can see what you'd see before you buy. |
Check if you're local to some clubs - we had one where I grew up in Grand Rapids MI that even had a fixed location with far nicer equipment than I was/am ever going to have. Lots of light pollution, too, but you can't win them all. Lacking that, the above mentioned "dark sky nights" might scratch your itch and are basically free. Also, those people are gear-heads and usually have stuff to sell for a steal. Frankly, spending the money on a trip to a truly dark sky location (bortle 1 or 2) like Death Valley or central Nebraska, a blanket and some basic 7x50 binos may be far more rewarding than a small scope. Skies like that don't even seem "normal" to me - so many stars that it takes a few moments to get your bearings, and I live in the NM mountains where you can easily see the milky way while driving down the highway. |
Well, I do remember being absolutely stunned at seeing my shadow by starlight. This was back in '70 when I was in Texas. I wasn't into astronomy much back then, so it really blew my mind.
| All times are GMT -8. The time now is 09:00 AM. |
