-   -   External Hard Disk - USB HDD - what Brands? (http://forums.pelicanparts.com/off-topic-discussions/687179-external-hard-disk-usb-hdd-what-brands.html)
RWebb 07-04-2012 02:08 PM
I am looking for an external hard disk drive to backup my PC (and maybe even transfer all my files over to a Mac).
I hear various concerns about quality for Seagate and sometimes others.
As usual, there's no reason to waste money buying more than I need, so I think 1 Tbyte and USB 3.0 should do the trick.
what brands or models should I get?
(WD, La Cie, Seagate, Toshiba are commonly seen in web searches)
TIA
Flieger 07-04-2012 02:50 PM
I have a WD that I use like a thumb drive (I don't use the backup software that comes with it) but after about 1.5 years it appears that it has gotten a worn out segmet as there are a couple files that I cannot modify (erase) but everything else functions normally.
Just to give you one data point (or a datum if you prefer).
stomachmonkey 07-04-2012 02:58 PM
See there's the problem.
I have never had a Seagate fail and have had nothing but problems with WD.
Hitachi have been good to me.
I'd buy 2 and mirror or 3 500's and go raid 5.
Flieger 07-04-2012 03:00 PM
I bought the WD because it was cheaper. I figured the chances that both it and the laptop's hard drive would fail at the same time were low enough to go cheap. By that I mean total failure.
Bill Douglas 07-04-2012 06:24 PM
WD Elements.
And use Ghost to make an image backup onto it.
gassy 07-04-2012 06:45 PM
Never had any problems with La Cie. I have about 6 of them.
Icemaster 07-04-2012 06:52 PM
Maybe a separate NAS drive that you can add to a wireless network?
jyl 07-04-2012 08:45 PM
Bad luck here with WD consumer level drives. No bad luck with Seagate so far.
RWebb 07-04-2012 08:58 PM
that's WD -2
Seagate -1
greglepore 07-05-2012 07:15 AM
Have used both brands.About equal quality IMHO. Now that they're cheap, I have a 1tb WD that | also back up to a 1tb Iomega. Might make sense to check out cloud services these days.
Scott R 07-05-2012 07:21 AM
Stay away from Western.
gr8fl4porsche 07-05-2012 07:33 AM
I have a pile of dead drives - all brands.
Bottom line is if you use them often (the cheap consumer ones) - its just a matter of time before they die.
I play with huge files - audio and video. The drives then to write and access for a long time. Maybe that's why my drives only make it 3-4 years.
I buy from Newegg and stay away from the models (not brands) that people return the most. Read the reviews. If you notice a trend in lots of DOA and dead drives after a few months, then move on to the next one down the list.
gtc 07-05-2012 09:58 AM
+1 on reading the newegg reviews. all brands seem to have their good or bad models.
RonDent 07-05-2012 04:13 PM
I just got a 2 Tb G Technology External drive. I'm very happy with it. The company discount is nice too.!
