HiBeam's Avatar
Question Sandblast Teflon pans?
So what does the forum wisdom think of this method of saving a couple of my favorite aluminum pans.
Their glass covers fit tightly, so I don't like the thought of tossing the two.
Any ideas? Heating them to 600 - 700' is out of the question.
BTW, I won't be buying any more Teflon pans.
'99 R11S, '76 914 2.0
Old 07-31-2012, 01:29 PM
andrew15's Avatar
Are you planning on recoating them with something else after removing the teflon?
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 07-31-2012, 01:46 PM
Model Citizen
herr_oberst's Avatar
I would CAST those pans into a big pile of IRON and get some new ones.
Old 07-31-2012, 01:52 PM
vash's Avatar
sorry.without the teflon coating, they will just be useless..even if they are all-clad pans.
toss them. buy your future teflon from a restaurant supply store...even my 12" is just about $25. use them and keep replacing them. i wont buy high end coated pans. keep the lids. lids dont need to fit perfect anyways.
poof! gone
Old 07-31-2012, 02:01 PM
Bill Douglas's Avatar
Throw them out.
The new generation of aluminium pans are much better I use Cirulon Circulon.com - Cookware Home and the non stick is incredible. They take quite a while to heat but they don't burn, and did I mention nothing sticks.
Old 07-31-2012, 02:15 PM
RETIRED
Joe Bob's Avatar
Float tests......
2012 ML350 3.0 Turbo Diesel
Old 07-31-2012, 03:56 PM
Detached Member
Hugh R's Avatar
Toss them, you won't get a mirror finish and they will be a pain to clean.
Hugh
Old 07-31-2012, 03:58 PM
HiBeam's Avatar
No, I plan to use them as the aluminum pans they are, after removing the Teflon.
I don't see how they would be useless w/o the coating. I have aluminum pans that were born w/o Teflon coating.
Old 07-31-2012, 04:04 PM
HiBeam's Avatar
Oh, so it's the lack of mirror finish that would render them useless?
Old 07-31-2012, 04:05 PM
DanielDudley's Avatar
Don't cook in bare aluminum. Acid breaks it down, and you don't need it in your system.
Old 07-31-2012, 04:16 PM
use cast iron, properly seasoned they work just as well.
Old 07-31-2012, 04:26 PM
Now in 993 land ...
aigel's Avatar
The blasting will put stress into the metal and they will deform. Ever sandblasted a thin metal sheet? This compressive stress buildup is used on purpose when shot-peening parts, i.e. connecting rods, but not good for your pans.
I would take the lids and go to WalMart or your local outfitter store and get a set of Lodge cast iron pans that fit your lids. These are cheap and cast iron is the best pan you will ever have if you use it properly.
G
81 SC (sold)
Old 07-31-2012, 04:37 PM
Aluminium warps when sandblasted too....
Aigel beat me to the punch....
Zeke's Avatar
It would be great if you could machine the interior of the pans. I think AL seasons like CI. Don't wash them, wipe them out. Of course, you can't mess up and burn something in them.
Old 07-31-2012, 05:07 PM
