Do an unoffical audit. You must have an idea of what parts are purchased and can find out who your suppliers are and what the bits cost. Even if he is scamming an extra hour or two here and there it is cheaper than getting an engineer in for this and a different engineer in for that.
Edit: A trick I used to do to get onside with people like this would be to approch him and say "I appreciate the skills and knowledge you have in this field and I wonder if you could help me. Upper mamagement has asked me to cut costs in maintenance and expenditure so could you show me around and tell me what you have planned so I can back you up if they start making demands." |
This is a simple one to fix:
Make a WOMAN his boss. She will ride his azz all day, everyday. Problem fixed. SmileWavy |
I read the OP a few time to make sure I didn't miss anything. So far, Higgins has the best insight and fairest assessment of the situation. But no solution as to what to do about the lack of control over the maintenance guy's MO.
Some changes in this guy's MO would be in order. Thing is, from what I read, he is going to be highly resistant to any change. I would do 2 things: explain in no uncertain terms why any changes are going to take place, and make those changes slight and a little at a time until you are satisfied that this employee is benevolent for your company. Total objectivity is paramount here. Forget about hearsay. I would also ask the maintenance guy for suggestions as a way to get him vested in your objectives. And remember your position at all times. Sometimes you have authority over subordinates but you don't have seniority. |
I try to keep my eyes and ears open and learn a little each day from the guys who actually do the work, but I have to be careful not be taken advantage of though and separate the crap from the truth. Quote:
There are two questions really. Does he need controlling and how to do it if that is the case. |
What are you manufacturing?
Question: If the plant goes down due to something that should be on a regular Preventative Maintenance cycle and you have no proof whether it was performed or not since there is no accountability, whose a$$ is going to be in the sling? Yours or his? Yours. You are not controlling him, you a managing your plant. |
Mine ultimately.
Manage processes, lead people.
Let someone else take this one on. But, yeah, most people are accountable.
There is a guy like this at my wife's work. He's in the Longshore union but all he does is clean bathrooms and sweep. Comes in a couple hours before the gangs and goes home after 8 hours. He's got a steady 5 day/wk gig whereas the Longshores may work almost anytime, mostly day and evening shifts and not too many weekends. This guy is hardly seen. He's got some kind of forklift he drives with a bin on the front with a broom, rake and shovel. I guess he gets the big stuff but the pier he takes care of along with the facilities is a half mile long and 500' wide. He's supposed to keep the weeds in check along the fences and keep stuff out of the storm drains. He's marginal at best on that. He really can't get in any trouble for his performance because he is union. No one but union can clean or pick up any trash. The large open areas in and out of the warehouses are done by a street sweeper. Another union guy with an equipment operator license. But he'll go within 6' of a fence, equipment, pallets, etc. leaving a lot of perimeter to maintain. I don't know what the basic pay scale is, but the cleaner/sweeper makes $70,000 a year, I'm sure, with vacation and all the trimmings. You talk about protective of his job. |
I don't think you're being very helpful KC. Control is the wrong word admittedly, but you are being awful judgmental. Whats the right word then?
The intent of the original post, was to find out how a maintenance department or maintenance worker's time is allocated, documented and accounted for. Thanks for your help so far. |
How big is this company and what does it do?
Sounds like there are more things lacking at the company than the maintenance guy. Unless you run a hair salon, any manufacturing business should have a PM schedule, a spare parts system and work orders. G |
Jeff Higgins made a good point in "if it ain't broke then don't fix it".
Having dealt with over-management I tend to agree. But since this seems like a larger institution where a great number of money/jobs depends on a single person without any type of accountability.... Where is the backup plan? If that single maintenance guy is "down for the count", and equipment breaks, what are the options? Lay everyone off? Who else knows what parts to order, from where, and how to install them? That seems to go against the nature of business. |
The thing that rings out for me from the original post was only touched on by one follow-up post: this guy has YOU afraid to talk to him. I don't know, did you say he cannot be fired? Because if he can be, that is the ultimate leverage you have over him and that should inform and empower you whenever you are dealing with issues regarding him. If you are talking to his direct supervisor, it should be at the back of your mind. When you are talking to him, it should be at the back of your mind. Until you get used to really being the boss you are going to have to force yourself to remember who fires whom!
Trust me, fire a couple of people when you are justified in doing so, and people will respect you. The trick is to be justified in doing so. That is accomplished by two things: having a track record that is visible to the entire staff that you are unassailable (you are hardworking, honest, and care only about the company -- first in, last to go, that kind of thing). In that regard, it wouldn't hurt for you to learn more about his job. This may mean you have to work harder and longer hours to get a better understanding of what he does (and other employees, too). But you said yourself that you are on a steep learning curve: you may not make it up that curve without putting in a lot of extra effort. Secondly, the employee must be truly in violation of a company policy or a standard that you have set. Remember to publicize the firing -- don't be afraid to yell at the guy in front of other staff if he gets out of line. When he gets released -- people will already know the explanation! I am a mild-mannered gentleman and as part of my maturity running my own businesses I learned that there were times when drama was in order. I had to become an actor to get my job done. There is A LOT of good advice in this thread, including specific advice on how to run a maintenance department, and "tricks" to get this guy to tow the line. Don't forget that it's not just a line from a movie: keep your friends close and your enemies closer!;) |
lighten up on the guy, maybe jus a lil? |
as suggested implement a new documentation plan in small increments. if the plan is implemented, EVERYONE does clocks their hours spent on task. don't single out a person.
don't say that you're trying to find out how many hours HE spends on a task. rather, you're implementing a system to prioritize tasks and get a hold of how many hours the each department that the employee is fixing stuff for is using the employee's time. |
| All times are GMT -8. The time now is 03:12 AM. |
