Hard wood floors - Engineered vs. Solid & Click together vs. Glue Down
We're about to replace a bunch of carpets in our house with hardwood floors.
Background: We have an 8 year old house, built on a concrete slab. At present, the downstairs is mostly tile but has 3 rooms plus a walk-in closet that have carpet installed over the concrete. We are not touching the tile. Originally I was looking to use click together hardwood floors. The stuff uses a thin layer of wood with a heavy duty compressed fiber board (basically cardboard) in the middle. It is about 3/8" thick. I looked at some higher end engineered wood, which uses plywood in the middle and has a real wood layer of about double the cheaper stuff. This requires the wood to be glued down. It is also about 3/8" thick. The best looking stuff is 3/8" Brazilian Koa solid wood. The stuff looks fantastic and the grain and contrast on the boards is best. This is also my wife's choice. Looks amazing. The floor guys are saying any of the items would be a good choice. With the glue down, we'll need to use a self leveling compound to make the floor perfectly flat first. Then use of a special sealing urethane glue with the vapor barrier built in. So, more work on the install. I would really like to use the solid wood, glued down to concrete. Will this really work? The stuff definitely looks way better than the engineered wood. But the engineered wood looks way stronger with the plywood underneath. And the glue down engineered wood looks much stronger/better than the click together engineered wood. And before someone suggests we put plywood down first. The house has tile. I do not want a huge transition between the tile and the hardwood. Even the thinest plywood underlay would make a 1/2" difference in between the tile and the hardwood. Suggestions? |
James, I hope you don't mind if I pile onto this thread rather than start a new one. I am in similar situation...wife wants to replace the rec room/basement carpet with Pergo (click together hardwood). The room has a ton of stuff in there.
My question for those that have been there....can I lay some of the floor and put the furniture back on it before the room is "done". ie baseboards nailed down??? I have no place to move everything in that room and I'm sure as hell not taking it all upstairs. |
One consideration is that moisture can wick thru concrete . I put solid hardwood down on concrete slab on grade. Added moisture barrier and ply subfloor and still got cupping in the flooring from the moisture.
Cheers Richard |
We have both. Main house 3/4 hard wood, vs apartment engineered wood. The apartment doesn't get much traffic since it is unoccupied. The apartment is also on a slab. I prefer the hardwood too. The hardwood is definitely showing some wear from chair legs in the dining room, though I prefer to call it character. We are looking for a larger area rug to help protect the wood.
The engineered wood is not showing wear, but like I said it is basically not in use. |
Just did this in our house with Bellawood Brazilian KOA. beat flooring I've worked with. I'll post pics when I get home this evening. Not a single warped board in 16 cases. Let it acclimate to the house for a month, filled some spots in the slab, then glued it down.
Hardwood questions Engineered vs. Laminate Wood Floors I have posted my experience in all of them. I prefer glue down install over concrete slab and nail down over wood. The floating laminate I put in my kids rooms and office is quick and easy but I dislike the sound and feel. YMMV. |
I have done some rooms in our house (concrete slab), following the instructions that came with the stuff, and have had no problems in 10+ years.
These are good for furniture moving: EZ Sliders™ 8-Piece Furniture Moving Set - Bed Bath & Beyond Use a sacrificial flooring piece/board to move from the unfinished to the finished side. |
We used the solid koa....I have to say I think it turned out rather well. Was able to bring up pics from this computer, so here's a few for you to check:
http://forums.pelicanparts.com/uploa...1349888225.jpg http://forums.pelicanparts.com/uploa...1349888252.jpg http://forums.pelicanparts.com/uploa...1349888273.jpg http://forums.pelicanparts.com/uploa...1349888288.jpg |
My kitchen floor is going down next week and I've been all through this recently. So many opinions and so many options.
Mine is going over a plywood subfloor with a dry basement underneath. I didn't pay a lot of attention to application over concrete but I do remember some basics. Solid wood is much less dimensionally stable than engineered wood. In a situation where moisture can be an issue (humid climate or the location of the floor) solid wood was not recommended by anyone, anytime. In Houston I would use engineered wood. My friend in Sugarland has lost 2 roofs (and one hardwood floor) in the past five years. Are you looking at literally gluing the wood to the concrete, or gluing the boards together? The most dimensionally stable system seems to be click or glue together engineered wood floated on the subfloor. I went with 3/8 inch, four or five ply (I don't remember which) tongue and groove boards that are glued together. They will float on a 1/8" pad made of recycled tires. On the demo floor this system sounded and felt very quiet and solid and everyone says it is the least likely to buckle. |
VaSteve: Yeah, we did ours 1/2 and 1/2 to have some place to put furniture. Let it dry overnight so it does not shift. Another tip: use blue painters tape to tape each board down to the next so there is no shifting during install & drying. Saves BIG headaches if you do it this way. 4-5 strips across to the previously laid board does the trick. Oh, redbeard, the wood is actually a bit darker than in these pics (loads of sun and house lighting makes it appear light in spots.
EDIT: Bella has a special adhesive for this application...Don't skrimp! |
Red,
I have a buddy who sells floors. Let me know if ya want me to get in touch with him to get you a good rate. |
I was planning to use the Urethane sold by the Store (Lumber Liquidators) and get the self leveling compound from them as well. This way it is all compatible and the warranty matches. Quote:
Yes, we got all of our supplies from LL. As I said before, zero problems with the install, zero wasted boards. You can find cheaper material, but we wanted to do it right the first time.
red-beard,
In regards to your last posting... we are in process of doing three rooms in our house with 3/4" hardwood. We first went to Lumber Liquidators and really liked the choices and price; however, after doing some Internet research, this organization had some really, really bad reviews. A multitude of complaints were filed with the BBB which seemed to mirror the complaints we read online. We found a family-owned flooring business and will probably go that route (they visited us just yesterday). Oddly, a representative from Lumber Liquidators called me last week inquiring as to whether or not we had made our decision with the hardwood. I stated that we were definitely going along with our original plans for the three rooms but we were really concerned about all the negative feedback with Lumber Liquidators. Her reply was simply "do you want to close out your request". Never once did she even attempt to convince us otherwise or to even defend LL... I was not sure if you were buying your flooring materials or just the Urethane from LL. |
Daryl, we are buying the materials from LL, but the work will be a local contractor. They prefer we buy the materials.
Unless Tom's buddy can come through. James |
Make sure you are not getting cabin grade. You get what you paid for. LL might be cheap, just make sure you know exactly what you are getting.
Talk to your installer in detail and make it clear as to what it is that you want. My installer always gets my floor. Spec out the floor and have them get it. it usually comes out to be about the same because they get it at a discounted rate. My advice is to have them get the floor leveler because they are use to working with a certain materials. They can do it in their sleep. Personally, I like the 1/2" to 3/4" solid floor. Rift White Oak, or Maple floor are my favorite. Glue to concrete slab or install over a sub floor. I DO NOT like floating floors or floors that are 3/8" thick. Engineering floors are OK, but not my first choice. Just think, you don't see them making gyms out of engineering flooring, do you? At least I don't know of any. |
Allow solid lumber to acclimate in the home for a week before install. Make sure there is air space between bundles.
James, did you ever do this project?
We gave some thought to walling off part of the basement (the idea was to keep the pets out) and re-carpeting it, but due to the cost decided again to go with the laminate flooring. The project won't be done for a few weeks, we need to clean up some of the room first. This is what I'm looking at...a 700sqft room. I'm a little intimidated by the scope of this project. Cutting and laying floor is no big deal, it's the moving of all this stuff. Behind me, is a couple of workout machines. We're going to drag them into the unfinished area. Most of the junk in there is my wife's or stuff of the kid's she won't part with. She's going to clean it up, so it's a win-win. I'm not enamored with the thought of removing all the cat pee carpet myself, but I will be glad when it's gone. http://forums.pelicanparts.com/uploa...1369748149.jpg |
A little late, but one thing to consider is the difference in thickness of whatever wood you put in, including underlayment, and the clearances of dishwasher, trash compactors, refrigerators and the door clearances. You don't want to put in some hardwood and find those items won't fit any more.
Holy moley. I just finished the bulk of the work. It was like 61 boxes of the stuff. Putting it down is no big deal but this room has some odd nooks and crannys and a 45 degree wall with a door in it. You can't see it in the photos. I just have made a thousand trips up and down the stairs to the garage to make a cut, redo it, over and over. Gotta wait till next week for the quarter rounds and final trim. Looks nice. Room is very cool.
Sorry, I must have missed when the thread was revived. Yes, we put down engineered hardwood. We went with the Bellawood because it had actual plywood in the middle vs. MDF.
Came out great. |
I used a prefinished engineered wood from S&S Flooring in So. Cal. I'm sure there's an equivalent source closer to you. Real wood is classier than plastic laminate. YMMV, but it depends on the room and its purpose. Laminate is cheaper to install and will probably stand up better under kid activities and claw marks from your giant pet.
Should be available in various thicknesses and widths. Suggest thicker the better. Some brands can be resanded and refinished X times. Mine was 2" wide x 7/16" thick T&G, glued down over concrete. Packaged in random lengths. As others have suggested, make sure the concrete is flat and ambient moisture content is below the recommended threshold, otherwise longevity with flat floors will be iffy. Fitting regular furniture with wavy floors is tough. Add in the cost to install or DIY. Use the recommended materials and brands. Some dealers will try to include damaged and/or borderline appearance pieces. The initial cost/sq. foot might be cheaper, but those pieces are unusable - scrap or firewood, and increase the project cost. Make sure the company stands behind their product. Referrals and recommendations are suggested. I too have heard of some complaints about LL, it's a franchise operation. https://www.google.com/search?q=engineered+wood&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a&um=1&ie=UTF-8&hl=en&tbm=isch&source=og&sa=N&tab=wi&ei=3dXXUa7D NaTviQKVvoGoDA&biw=1566&bih=1149&sei=49XXUanCO4aZi QKn_IGwAw#imgdii=_ Hope this helps, Sherwood |
I did some sub-contracting through LL during the depression. Their wood is mostly seconds. The Bella line was o.k. The extra labor to remove bad pieces and sort through the bundles is just not worth it.
I had never worked with LL before, I always thought that's what they did. I didn't realize they had news stuff until my wife started shopping for this project. I have yet to nail down the quarter rounds...that's today's project. As well as next weekend since some of it's not in stock. |
Glad someone resurrected this thread. My post (quoted above) turned out to be wrong. The installer came out and said trying to float the floor in my kitchen would be a disaster. There is an island and too many nooks and crannies. He said floating would have been fine it the floor was an open rectangle, but it is so cut up that it would expand and contract differently in different places and buckle. So it's stitched down, 5 ply engineered hardwood. Looks great, reasonably quiet. Time will tell about how stable it is.
In my townhouse I glued engineered wood to the concrete. It was cherry and did not wear well. The worst job ever is trying to get an engineered product off the concrete. Three laborers and myself with one very large and expensive powered scraper. The new wood floor is floated and serviceable. I will never again glue down a wood floor, at least for myself.
Since I was going over concrete, I went ahead and bought a moisture meter. I'm glad I did. We found lots of moisture in the bedroom. The flower bed outside the window was not correct. I dug everything out, put in proper drainage and converted it to just broken marble. Most of the plants went into pots instead. If I hadn't fixed the moisture problem, I'm sure it would have been bad down the road.
Some say a floated floor doesn't feel like a solid floor. This bothers some owners, others not. YMMV. Sherwood |
The sound of a floating floor is definitely different. If someone would rather have their wood glued down they should remember that they might have to take it up one day.
I'm not quite done...all the molding aren't in, but I can confirm the "feel" is a little different than the hardwoods upstairs. This is 12mm material with padding glued to the back. In some spots, I can feel the slightest of movement. I wanted to see what my guitar sounded like in the room. Cranked the little amp up while it was sitting on the floor and I could feel it in my feet. :)
| All times are GMT -8. The time now is 10:54 AM. |
