When selecting motor oil~
Which wt do you use?
Which brand? Why? Does a different wt help a high mileage motor? So many choices and suggestions. I use 5-20 cheap-o synth in my Ford race car, 20-50 Castrol in the Porsche and it's time for an oil change in the high mileage Volvo ( 170k ). I forget what I used last. Whatever the parts desk guy suggested at the Volvo dealership. My Ford F-350 diesel get's oil service every 3k at the dealership and I am embarrassed to admit, I have no idea what oil they are using. Delo 400? Who knows? I'd like to hear some ideas and experiences on this. Also some insight on the differences between wts would be helpful. thanks! KT |
oil weight depends on the motor. every motor's going to have different requirements. 5w20 seems to be general consensus for fuel savers now. 5w30 for most passenger cars.
brand...that's up to you. brad penn, amsoil, swepco...you pay for it. |
5-30 Mobil One from Walmart. Good quality and cheaper than at an auto parts store.
Castrol 10w60
I doubt you will get many opinions on motor oil here on Pelican.
The general consensus will be "Whatever is on sale". |
Have a look over here
...all the same...hee hee
organic jojoba bean oil that is sustainably harvest by a collective of local farmers wearing anti-Nike T-shirts with ZDDP added by a trio of Wiccan lesbians chanting "cauldron smoke and fire bubble"
20/50 Penzoil or Quakerstate only for 40years now in everything from my 426 Hemi to the 2.7,3.0,3.2, 3.3, 3.6 , Race car, .Never a problem
i'm amazed you dont do the truck work yourself..
They handle it every 3k miles. It cost me $600. I just got an ad in the mail from the dealership today for the service, $105 for oil and filter. I'll be taking it in for the 50th time next week. ( over $5k worth of work so far ) They work on it while I sit in the waiting room, surfing PPOT and sipping coffee. KT |
hard to debate that math!!
Plus, they dispose of the 15 qts and big filter... :D
KT |
I do the Mobile 1 from Walmart thing for my wife's car along with RPM Delo400 and filter for the truck. I follow the 5K mile oil change schedule for the truck. Soon after I got it, I bought a bypass filter and installed it. I read that is one of the major things you can do for longivity, but what do I know. 55+ years ago when my father worked in the service station business, he always said RPM Delo was one of the best oils.
In modern turbo diesels, you'd better use full synthetics. They're exhibiting lots of problems if you don't
Eric, I challenge that. I can provide several proof statements to the contrary. I have done several case studies that pitted a full synthetic to a very well developed mineral based oil and the mineral based out lasted it. Depends on how the mineral oil based lube was made but sadly many are poorly developed...
How about: "If you're buying your oil off the shelf at Wal Mart or Pep Boys, you'd better be running full synthetics in cars and light trucks with modern turbodiesels" Better? I'm not talking Class-8 semis or Caterpillar mining equipment |
my brother runs rotella in his duramax. i think.
Only Rotella T6 is full synthetic. And if he's not running it, he's going to have turbo issues. Unless he's changing it often, running it hard, warming it up and cooling it off, and keeping the PCV and EGR systems clean. |
I'd still like to know why certain motors require a certain oil wt.
what role does climate play? KT |
Mobil Delvac in my diesel. Cheap at Walmart.
For climate effects look in your owners manual. It will clearly show the thicker oils for warmer weather. I believe this is almost all 'start-up' viscosity, I don't think running viscosity can change much, as the engine temperature doesn't change. |
| All times are GMT -8. The time now is 06:44 AM. |
