-   -   Cheap Under Counter Lights (http://forums.pelicanparts.com/off-topic-discussions/716835-cheap-under-counter-lights.html)
1990C4S 11-14-2012 07:21 AM
Looking for some cheap ideas for under-counter lighting.
I am thinking along the lines of either cheap Harbor Freight fixtures wired to a power supply, or buying LED's and making buying LED's and making a 'fixture', or buying strip LED's.
Or maybe I should just go to IKEA. But I do enjoy the DIY portion.....
LED Under-Cabinet Light
RATIONELL LED countertop light - aluminium-colour, 40 cm - IKEA
LED Strips - SMD 3528 Flexible LED Strips 300 LEDs
Christien 11-14-2012 07:57 AM
My in-laws have LED under the counter lights in their kitchen. Absolutely useless. The light level is way too low. Maybe 10-20% better than nothing.
lane912 11-14-2012 08:01 AM
super bright leds .com
john70t 11-14-2012 08:15 AM
I've got a 2' fluorescent with a GE plant/aquarium bulb(full spectrum).
With the yellow backsplash it gives a comforting warm glow.
look 171 11-14-2012 08:41 AM
I am still old school and use halogen or xenon(a lot less heat) lamps under there. The reason for lights under there is to see, not to save on electrical bill. LEDs have been used on various projects over the years but the good ones that put out lot of light are $$$. They work fine. We buy them from cabinet suppliers.
JavaBrewer 11-14-2012 08:58 AM
+1. I yanked the existing under cabinet fluorescent light fixtures, ran the 110v to a central location and used that to drive a bunch of cheap halogen puck lights under, inside, and on top of my kitchen cabinetry. Looks amazing. The bulbs are hit/miss for longevity and usually go about 6 months. But again this setup is all about lighting and appearance - not saving $$.
1990C4S 11-14-2012 09:13 AM
That's a selection issue, not a true LED issue, judging from some of the pics I've seen.
I need low voltage.
MikeSid 11-14-2012 09:46 AM
You didn't specify the level of finish/appearance - i.e. Is this for a workshop or a kitchen?
I recommend this system.
Low Voltage Linear Lighting
look 171 11-14-2012 11:29 AM
The bi-pin lamps are just cheap they go out all the time. Quality lamps (Constant color that will not yellow) that last a long time are out there and they don't cost that much more.
Halm 11-14-2012 11:43 AM
If you are retrofitting your own kitchen cabinets, believe me when I say you want the lowest heat output light source you can afford. We had very narrow overhang on the cabinets to work with and the choice seemed to be between Kichler LED pucks or xenon lights. We cheaped out and went with xenon. Wish we hadn't. When we turn them up to "high" everything in cabinet above starts to get warm.
1990C4S 11-14-2012 12:17 PM
Kitchen. But they will ideally be hidden.
1990C4S 11-14-2012 12:33 PM
Four Head, LED Under-Cabinet Light
These are fairly bright. And ugly. They need to be hidden.
Rusty Heap 11-14-2012 02:35 PM
Home Depot and Lowes sucks major for choice in this department............put me in the "I don't care about the electric bill I want to tan under these puppies, while having slim hidden design for the wife acceptance factor........."
subscribed.
creaturecat 11-14-2012 04:31 PM
I would use led strips.
There are some great ones out there.
A930Rocket 11-14-2012 04:51 PM
I've had florescent and halogen just for accent lighting. Florescents are too bright and the halogens make the cabs so hot, you can warm bread in them.
Maybe LED's or rope lighting. The rope lighting looks good in tray ceilings.
Rusty Heap 11-14-2012 04:56 PM
Please do expand on such knowledge.
look 171 11-14-2012 05:04 PM
I have a little heat under there also. So what? A little heat isn't going to burn the house down. A normal light bulb creates heat but we all use them in our homes.
The placed I buy the under counter lights from is a wholesalers to cabinet makers/contractors but I can try and find something similar for you later tonight.
fxeditor 11-14-2012 08:54 PM
Check these out from Ikea!
KOMPLEMENT LED light strip - 36 " - IKEA
Good luck,
Michael
look 171 11-14-2012 10:08 PM
.lightingshowplace.com/kichler-10595-5-light-xenon-direct-wire-under-cabinet-fixture-from-the-direct-wire-low-v-xenon-collection/p860865?source=gg-gba-pla_860865____13519237368&s_kwcid=PTC!pla!!!384514 22328!g!!13519237368&gclid=CLbQwtyk0LMCFUdxQgodLH0 A_Q
Many clients seem to be happy with these. One thing, they are code because they have a BX knockout on the side of the lamp to a metal sheathed cable can be connected to the lamp disappearing up under the ledge of the cabinet and they are bright. flip the rocker switch and they dim out a little, about 40%. Mine are on daily in my own kitchen.
look 171 11-14-2012 10:10 PM
Four Light Undercabinet by Kichler Lighting : 12214WH : StylesofLighting.com
Let try again
