rfuerst911sc's Avatar
florescent light fixtures in the cold
Is there anything that can be done to standard 4 ' two bulb light fixtures to make them work when temp's fall into the 30's ? I have eight fixtures in one portion of the garage and they work fine regardless of the outside temp's. But four of them ( newer ) in a different section of the garage have a hard time " lighting " and make " noise " when trying to light. Is it the ballast that causes this ? When temp's are in the 40's or higher no problems. Any cure for this ?
Old 12-23-2012, 03:07 AM
I'm with Bill
Rick V's Avatar
I don't remember if it was the bulbs or the ballasts but one of them are designed for use in the cold. I went through this lesson a few years back when I redid the lights in my garage.
Old 12-23-2012, 04:29 AM
David McLaughlin's Avatar
It's the ballasts that need to be changed. They're about $20 at Lowe's.
1970 914/6 RustoMod
2015 Mercedes E400
Old 12-23-2012, 05:24 AM
MBAtarga's Avatar
Ballasts +1
Also, make sure the ground connection to power is good.
Old 12-23-2012, 05:38 AM
When I buy boxes of fluorescent bulbs I've seen warnings not to store them below 60 degrees.
76-911s 80-911sc
Regards Lester
Old 12-23-2012, 06:10 AM
redstrosekNic's Avatar
My 8ft fixtures take a bit to warm up when the temps are in the 40's. They do quiet down and become bright after about 5-10 mins.
Dustin
Old 12-23-2012, 06:37 AM
Cold environment fixtures AND tubes are designed for this and are different from heated environment lighting fixtures and tubes. I might also add the cold environment ones use more electricity and are a tad more expensive.
Go to a lighting retail outlet they will educate you on the subject.
Old 12-23-2012, 07:51 AM
1980 911 SC
Large commercial walkin freezers use flourescent lighting all the time.
Talk to your local electrical supply.
Life's a Beach
Old 12-23-2012, 07:59 AM
