do you have table saw blades sharpened ?
I've got several 10 " carbide saw blades that are now dull, does anyone still have blades sharpened ? And what about high speed steel blades ? Seems like the price of blades is so reasonable anymore that sharpening might not be cost effective.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Puny Bird
Costs me about $20 a blade, I don't buy cheap blades, except for rip blades they're all over $100. each.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
Almost Banned Once
It cost me about $30 to get mine done. I've had it done 2 times in 7 years. I only have one good one but three total. The other two I use for firewood etc.
If it ever lost a tooth on my good one I'd replace it rather than get it fixed.
- Peter |
Almost Banned Once
I have a Triton table saw. It designed to take a standard circular saw inverted.
Just pick up the log and run it through. My fireplace is smallish.
- Peter |
. Just picking with ya...we (my dad and I) actually have a cabinet maker that supplies us with several large loads of kindling a few times each year. "Firewood" requires chainsaws and hydraulic log splitters...and you don't "just pick one up"
After about the middle of November, I don't use kindling at all, The fire remains going 24/7 in my large airtight woodburner til about the end of April.
I generally buy cheap blades and replace if needed, but my 20" chainsaw chains get sharpened every year for about 10 years. |
In theory, if they aren't in bad shape I touch them up with a Dremel as long as they aren't so bad they need to be reset. In reality I'm usually in the middle of a hot project when a blade is too bad to use. No time to sharpen it. So I go buy a new one and tell myself I'll sharpen the dull one when I have some time. So I've only done about 2 in the last five years.
I find sometimes I just need to clean off the pitch and tar build up. The blades fit nicely in the bottom of an old 5 gallon joint compound bucket. I pour enough Lestoil in to cover the blades and let it soak. The Lestoil cleans them very well.
Ed 1973.5 T |
i've had all tablesaws removed from my property. i am clearly not qualified.
i'll save you new guys the pic..hehe.
poof! gone |
UnRegistered User
I just had 3 slide miter blades, 3 table saw blades and had one circ saw blades done.
Price was less than one good quality miter saw blade. Think I am good for a bit and ready to make some dust.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
We used to get the carbide blades repaired. New teeth welded on and sharpened. That was till someone figured out it was cheaper to buy a new blade.
Bunch of old cars
You get what you pay for. There are plenty of cheap carbide tipped blades out there that aren't worth sharpening. Generally they are about $.75 - $1.00 per tooth. Blades can run upwards of 150-180 dollars per 10" blade. For general purpose blade, a Freud is fine. We drop blades off once 6 -9 months. Skill saws blades are throw away blades, most of the time.
. 4 saws from 20" down, putting on an old "dirt chain" when needed. Not sharpening them "every time", just touching them up when necessary and to the "shop" when needed every few years. Some saws have been "workhorses" over the decades...not nearly as much these days.
I send my Forrest blades back to them for sharpening. I use Butler in Lawrenceville for my Freud and other higher quality blades. Cheaper carbides and non carbides just get replaced.
Almost Banned Once
- Peter |
I got rid of my tablesaw too because I didn't use it much and it took up a lot of room. It is an intimidating piece of equipment too. When I did use it, I used Forrest blades and did send them back for sharpening. I also cleaned them with Simple Green between uses.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
