-   -   Installing aftermarket head unit into my Avalanche (http://forums.pelicanparts.com/off-topic-discussions/725214-installing-aftermarket-head-unit-into-my-avalanche.html)
ErVikingo 12-23-2012 01:11 PM
Wow, got the kit from Crutchfield to integrate to my car (keep Bose amps and steering wheel controls).
Budgeted 3 hrs for this. It took me that long just to prepare the wiring harness... I welded and shrink tubed everything. Tomorrow I'll do the actual install.
Now i must figure out how to bypass the parking brake lockout feature (Pioneer AVH 3400 BH). Apparently a relay is needed (can't just connect to a power source; Pioneers need power not ground).
Hope its all worth it in the end.
Nostril Cheese 12-23-2012 01:15 PM
Get rid of all the Bose components and go Boston Acoustics or Focal. Then it will be worth it in the end.
ErVikingo 12-23-2012 01:21 PM
Agree but this is the utility truck for the family. The good stuff goes into the toys and the music room!
dad911 12-23-2012 01:24 PM
Welded or soldered?
Use a momentary pushbutton for the parking brake.
ErVikingo 12-23-2012 01:30 PM
Soldered. Sorry.
Could you expand on the push button solution please?
dad911 12-23-2012 01:54 PM
Green Wire? I don't remember if it has to be a normally open or normally closed switch. Sorry but I'd need to pull it all apart to remember what I did.
I think it connects to ground normally, but pushbutton breaks the connection momentarily.
sc_rufctr 12-23-2012 05:41 PM
Looking at the title, I thought.... :rolleyes:
http://forums.pelicanparts.com/uploa...1356313237.jpg
http://forums.pelicanparts.com/uploa...1356313287.jpg
ErVikingo 12-29-2012 05:32 PM
Peter, those had more relays than a 928....
I completed my install today. Sounds awesome! Added a "micro relay" to address my concern. A suggestion to those thinking of doing this, run the auto eq settings before installing the relay, i cant now 'cause car must be parked to run auto eq....
I have good ears so it was done the old fashion way.....
onewhippedpuppy 12-30-2012 06:52 AM
Spent the better part of a day doing the same thing on a Silverado Classic last year. I don't recall how I avoided the parking brake thing but I did. What an incredible pain in the ass! I've done a lot of stereo installs, that was by far the worst.
ErVikingo 12-30-2012 08:24 AM
Puppy,
I did a mod to my wife's Denali 07, that was a real nightmare. The car has a main wiring harness that runs most everything and you mess with one thing and something else gives up....
