Finger vs. Pressure Washer **Warning, graphic picstures**
I thought that since no one else would step up and teach PPOT how to NOT properly use a pressure washer, here is my contribution:
1. Make sure you're not wearing gloves 2. Be VERY stupid and believe you can hold a wash mitt and clean it with the pressure washer 3. Let pressure washer slip in your hand and almost take off pinky when it hits the finger for less than 1 second. And to make sure I get my point across, here is a visual of what will happen if you follow my easy steps: http://forums.pelicanparts.com/uploa...1356985207.jpg What the picture doesn't show is the pain my finger is in. Not right when it happened, no way, it gave me a sense of "it might not be that bad"...no the pain came about 20 minutes later when my brain caught up to the fact that I almost cut off my damn finger. Yes, I know I was stupid, I have washed the mitt this way before and apparently have gotten lucky all those other times. Luckily I had a fairly wide tip on or I might be writing this from the ER with my pinky tip in ice!:D How messed up is this...my first thought was to get a picture for PPOT right after it happened:p |
I think you may be doing it wrong. ;) Ouch!. We all slip once in a while.
OUCH!!!!!
Hurts to just THINK about... angela |
At least he knows it was clean!
Was at Home Depot one day when they were doing a demo with pressure washers, they were cutting oak pallets with the pressure washer. Instant respect from me !
Yep, I should have known better. We had a 4000psi version at the dealership I worked at as a detailer (owner was a "bigger is better" type) and with the smallest angled tip we would easily cut concrete.
The pain is starting to subside finally, but that could have something to do with the ibuprofen I took:) |
Wow. Did the end of the finger fill up like a water balloon? :D
Heal fast bud! |
no, but the skin peeled back around the cut and I can feel the cut is deep, although its more like a blood blister...very odd injury which at the moment it happened, I thought it was going to be a lot worse!
We use 25,000 psi blasters at work and occasionally have to bring in one rated at 40,000.
The operators look like knights in armor with all the protective ...well... armor they have to wear just in case. Those things scare the hell out of me and I'm fearless ;) |
wow, what the heck do you do to require 40,000psi blasters?Those would be fun to etch steel with!
I hit my foot with one from my summer job... It hurt.
We have hundreds of those radiators in the plant. The inside of every tube need to be cleaned to bare metal every so many years for inspection and corrosion measurements so they run a high pressure "whip" through each tube to get em clean. The 40k machines can usually do it in 1 or 2 passes. the 25k machines take more. http://forums.pelicanparts.com/uploa...1356998105.jpg http://forums.pelicanparts.com/uploa...1356998119.jpg |
What psi do water jet cutters use?
Depends. Quote:
Good to hear it isn't too bad. Done it many a time and gotten away with it.
Not to take away from your story, but its funny you mention getting a picture for PPOT! I got my hand stuck between a drill nose piece (a very large $4M drill and the work surface when I was careless last month). It was my turn to hold the dumb end of the operation and had to teach the operator how to back the nose piece off my hand while pinned for several minutes. She was freaking out and I thought she might faint. No blood and guts or broken bones, but did it hurt and still hurts a month and a half later. One hour later: http://forums.pelicanparts.com/uploa...1356999055.jpg http://forums.pelicanparts.com/uploa...1356999095.jpg Next day or so: http://forums.pelicanparts.com/uploa...1356999152.jpg http://forums.pelicanparts.com/uploa...1356999176.jpg |
my friend a Pile Driver guy was running a hydraulic pile driver. the hoses get dragged around and they get cuts. we were standing right next to one when one ruptured. the pile-butt shielded his eyes and the stream almost cut his small finger off. i was dumbfounded!! he was squeezing yellow biodegradable hydraulic fluid out of the wound. it was gross. he refused to go to the doc..so i trumped him and called his boss. they rushed him out..the doc saved his hand. apparently, it could have been really bad.
heal up fast buddy!! do what the doc says. :D |
holy crap you guys!!Glad you're ok.
A high pressure injection injury to the hand is usually a surgical emergency. (Obviously it will depend on the depth of the cut.) The problem is that foreign material (whether it's paint, non-sterile water, etc) and bacteria get shoved deep inside the hand and finger and travel significant distances subcutaneously. Due to fascial planes, the bacteria can propagate and lead to serious infections without significant visible changes at the skin level. In turn that can cause scarring of the tendons to surrounding tissue, which then can lead to permanent stiffness. A surgeon has to have a very good reason for NOT going to the OR immediately if called to the ER to see this type of patient.
Some folks were born solely to serve as an example to others... Welcome to the club :P
| All times are GMT -8. The time now is 05:14 AM. |
