Computer Boot problem - XP
I have an old Dell 8300 running XP that will no longer boot. When you turn it on, the Dell logo does appear and the bar below the logo fills over a few seconds (maybe that relates to POST or drivers loading - I dunno).
However, I never see anything having to do with Windows appear on the screen -- it simply goes blank after the bar fills. Any ideas on what might be wrong? or what I might try by way of fixing it? |
Press "F2" before that bar completes, enter setup and see if your hard drive is being detected still.
If you have the XP CD/DVD you can boot from that and check the files on the drive as well if it is still recognised. Use the repair console and not the repair install.
first things first. open the case and vacuum/blowgun all the dirt out.
try hitting f8, f10 or f12. oem usually designates one of those to go to boot menu. from there it'll show you the messages as it boots. i would expect maybe a corrupt system file or something |
with my old laptop it was 1 of 2 memory chips bad. pulled the bad one out and everything back to normal
krystar - also hit F12 and nothing looks odd in boot menu; no log of problems either |
Try the Del key.
Dell's prefer flip flops to boots dude!
I also think the video is on the main board, but will see... |
found the reinstallation CD, which I think dates to 1879, so I can try that next time I go to the downtown office
thx all |
| All times are GMT -8. The time now is 07:06 PM. |
