-   -   Country Time Motor Meltdown (http://forums.pelicanparts.com/off-topic-discussions/729711-country-time-motor-meltdown.html)
126coupe 01-20-2013 08:09 AM
As I suspected, a broken crank up by the snout. Most parts look like they survived the mayhemhttp://forums.pelicanparts.com/uploa...1358701596.jpg
http://forums.pelicanparts.com/uploa...1358701627.jpg
http://forums.pelicanparts.com/uploa...1358701650.jpg
http://forums.pelicanparts.com/uploa...1358701672.jpg
http://forums.pelicanparts.com/uploa...1358701746.jpg
kaisen 01-20-2013 08:12 AM
Very unusual place for a crank to break. Like one in a million
I'd use a different manufacturer's billet this time around. If it was Crower last time, pick someone else this time.....
tevake 01-20-2013 08:14 AM
What a bad break, you going to be able to save the block?
Wonder what caused it to break there?
Any idea of the cost for a short block?
Cheers Richard
pavulon 01-20-2013 08:15 AM
was this an externally balanced motor?
kaisen 01-20-2013 08:16 AM
All small block Fords started life externally balanced
tevake 01-20-2013 08:24 AM
Does a race motor like that start with a factory stock block? Or is there race prep that is done on the block?
Cheers Richard
126coupe 01-20-2013 08:36 AM
I believe this was a forged crank, I am taking it down to Crower and they are making me a billet crank $$$$
126coupe 01-20-2013 08:37 AM
Cheers Richard
Block is fine, I am suspecting the balancer may have failed first
126coupe 01-20-2013 08:38 AM
Cheers Richard
This is a ford racing block it is stamped on the block, lots of race prep, mainly windage and prep for the dry sump system.
pavulon 01-20-2013 08:52 AM
Ok. But that doesn't make this an externally balanced motor. I'd wonder about bad harmonics in this crank failure.
kaisen 01-20-2013 10:33 AM
I'd agree that this was a harmonic balance failure
Looking at the balancer itself, it doesn't appear to have the 28oz counterweight so it appears to be internally balanced.
The balancer itself is a ATI Super Damper, which is a mechanical ring damper. It may have failed.
Consider going to a Fluidampr next time. They don't fail, and don't need to be serviced or rebuilt
126coupe 01-20-2013 12:15 PM
I believe ATI's are a good product, I did not know how many miles/hours were on this one.? The amount of hours I will run this dampener will break down to once a season. Nascar rebuilds after every race. I will check out Fluidampr also
