-   -   Tire plug or patch? (http://forums.pelicanparts.com/off-topic-discussions/730118-tire-plug-patch.html)
Chocaholic 01-22-2013 01:22 PM
Tire plug or patch?
Picked up a machine screw, about 1/4" in diameter in the center of a rear car tire (DD). Unscrewed it, reamed and inserted one of those 4" long black gewey plugs. Checked with soapy water and no sign of bubbles. Drove up and down freeway, came back and did it again....still no bubbles.
Any reason to have tire dismounted and patched? Are those plugs considered a permanent fix?
Thanks,
on2wheels52 01-22-2013 01:27 PM
I plugged a bunch of tires at the service station in the '70's with good results, but would have to say the inside patch is better.
Jim
iplagolf 01-22-2013 01:28 PM
I'm no tire guy but I have never plugged a tire. I believe it's best to patch it and re-balance. I always felt it disturbed (stretched) the area around the puncture.
Tim Hancock 01-22-2013 01:36 PM
I have probably installed 50-75 plugs in all sorts of tubeless tires over the years (ATV's, sports cars, trucks, mowers....). I do not recall EVER having one leak again from the same spot.
krystar 01-22-2013 02:19 PM
discount tire and just tires dismount the tire and plug patch it from the inside. for free.
so why not?
Chocaholic 01-22-2013 03:17 PM
discount tire and just tires dismount the tire and plug patch it from the inside. for free.<br>
<br>
so why not?
No Discount Tire for 80 miles.
Thanks for feedback. I suspect the plug will do the trick.
Rot 911 01-22-2013 03:35 PM
I'm with Tim. Never, ever had a plug go bad. Hell on the ATV I've shoved 2-3 plugs in a big hole and they have stayed in place. Probably plugged at least 10 street tires and the plugs have stayed right up until the tire is worn out and needed replacing.
krystar 01-22-2013 03:37 PM
dang that sucks!
if i remember correctly, cheap plugs causes fractures around the hole. but it's not like you're going to be hitting the track on plugged tires. so it'll prob be fine.
mikesride 01-22-2013 03:38 PM
plugs are ok on all seasons, would never use them on a speed rated tire. Not an expert just my opinion.
masraum 01-22-2013 04:48 PM
I've used plugs lots of times and only once had a problem with a plug that was leaking air through the rope fibers. I like them because I can do it myself.
But I think the best option is the plug-patch since it does both.
http://www.ducati.ms/forums/attachme...plug-patch.jpg
Tire Tech Information - Flat Tire Repairs
http://www.tirerack.com/images/tires...ure_ill_sm.jpg
fastfredracing 01-22-2013 04:53 PM
That plug will be fine.
944Larry 01-22-2013 05:58 PM
I've had tire people tell me to plug a radial and internally patch a regular tire. I've always done that with no problem.
weseeeee 01-22-2013 07:20 PM
I've plugged a bunch and so far no issues.
manbridge 74 01-22-2013 07:55 PM
From the same school of thought that brought you $15 brake pads, witness the cheap black plug. Leaks through fibers and can come out under duress/higher pressures.
Spend a bit more and get the thicker orange ones if you want to worry less/have more success.
I like to add the cement stuff to the hole and plug. Just for the heck of it.
Plug patches are superior in every way but aren't as convenient.
pete3799 01-22-2013 08:07 PM
Probably never have a problem with the external plug but if it was mine i would dismount and patch it on the inside.
I've been told that the fiber plugs can wick moisture in and rust the steel belts.
sammyg2 01-23-2013 06:44 AM
Given the choice I will go with a patch every time. I will only use a plug in an absolute emergency.
89911 01-23-2013 07:10 AM
I have plugged tires many times with never a failure. Sure you can get into tire bands rusting, integrity of the tire violated, high speed issues. yadda yadda. This isn't a tire that is going on the Salt flats and running 500mph and I don't usally get more then 2-3 years out of a set. Any large operation garage will never do this because there is much more profit in selling you a tire (or pair since they don't like to sell unmatched sets) to charging $10 to plug it. If the tires have to come off for any reason, I would put a patch on the inside since that is optimal, but only if convenient.
A930Rocket 01-23-2013 07:15 AM
Being in construction for years, I've plugged dozens of tires I've the years. Never a problem.
NY65912 01-23-2013 10:41 AM
Plenty of plugs. I plug as a temporary fix and then patch. Patch
Rot 911 01-23-2013 01:44 PM
Has anyone ever had a plug come out? Or even a friend of a friend's uncle? Not me.
