Need help for kid who want to enlist in Army Spe forces
Short tory: A kid (23 y.o) want to go into Army enlisting under a contract (18 xray) Special Forces/Special Operations. 5 year committment....AIT>>>>Airborne>>>>Spec For Prep Course.ide.>>>Green Beret...etc
He took the written test and cored in 90 percentile....95+ percentilt on PT College graduate. Problem is about 4 years ago he got a DUI contlled substance (marijuana). I got it reduced to a zerro tolerance charge and it was expunged. No drug involvement since o otherwise. When the recruiter leaned thiss...he told them as they aked if anything was ever expunged etc and he was honest....she immediately said he dcould not go under this contract as he would be disqualifieddue to security clearrance requirements. They would take him in RA but he could no go under the 18 xray contract. Any suggestions?
Jim 1987 Carrera 2002 BMW 525ti 1997 Buell Cyclone cafe project 1998 Buell S1W: "Angriest motorcycle I've ever ridden." |
No Band
True... the recruiter can not help. But, you need to have him take it up the chain of command. They can grant him a waiver. Have heard and seen it done before for similar type circumstances. Also, saying the usage if any was "experimental" also helps.
"HEY A$$MAN!!!" ![]() |
drunk and stupid
Recruiters are not the end all be all they like to think. Have him be brutallyn honest on the SF86 and with the investigators. It'll take a waiver, but shouldn't be a huge issue. I pushed a kid through for a TS/SCI MOS with a 130 in a 55 and evasion charge
What's the point of having your record cleared if it can still be used against you?
drunk and stupid
Most people can't. The DOD can find pretty much anything...
drunk and stupid
BTW 18x contracts typically have a very low completion rate.......then he ends up an 11b
I'd suggest an intel MOS, cross train to 11b then apply for SFAS |
Vafri
PM me; give me your ph #
HH944...sent you a PM
Hmm...somehow this seems odd. Active clearances are actually tied to billets (the need to know part of having one)...whereas eligibility is tied to a career field. Hence, you could be denied reenlistment in a career field should you lose your eligibility, but getting your clearance turned from active to inactive means little. With that, first enlistments will kind of be a guess at eligibility, as the investigation won't be completed until they are well into tech school or their first assignment.
Bottom line...find someone that will sign a waiver or MFR for his application. Being that he's not currently in...he doesn't have a chain of command so he should be free to look around. If that recruiter won't get it for him...go to another county and find someone that needs to boost their recruiting numbers. Last I checked...we aren't a one mistake military. He won't be a tier one candidate...probably a tier three...which just means it takes a bit longer to investigate and a higher signature on the package...acceptance of risk and all that.
-= Kaliv Farstryder =- '87 Porsche 911 |
Honey Badger
Find another recruiter? or service? The Army loves that contract, they use it a a recruiting tool to get people to sign up. They know the vast majority will end up as infantry, and that's what they want. Just because you are smart and in good shape, doesn't mean you will have a better chance to make it into SF. I know many people with a TS clearance that have admitted drug use before the military, and/or DUI (alcohol) on their records. Both of these did lead to more investigation, however. I couldn't tell you if this applies in his situation though.
A collage grad should have no problem enlisting in military, and getting the job of their choice. With a degree, and a clean record otherwise, a waiver should be easier to get than most I would think. The recruiter probably doesn't care, because that means more work for no gain.
1978 911SC 1953 Piper PA-18A USAF EOmfD |
Desertt5
From my experience, it all depends on how much they need him to make thier recruiting numbers. Back in the mid 2000's the Army recruiter next door to me was running all kinds of waivers for kids I could never put in the Marines.
As stated, try a different recruiting command all together, not just a different office.
Semper Fi |
Friend of Warren
Any recruiters job is to get kids in, what they call "making mission." But the OSUT pipeline to SF, or even Rangers (what I once was) is not the best way of succeeding. In fact it is the least likely way of succeeding.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Desertt5
Wouldn't he need the same waiver for an intel MOS? If not that route does make sense.
Semper Fi |
grist for the mill.
depressing. |
A marijuana possession charge (misdemeanor almost everywhere) is considered a felony by the Army. Waivers right now are pretty much slim to none since we're in a drawdown. We're cutting 80,000 people and going back to only bringing in "the best." My best friend's son is in the same situation. Recruiting for the Army is definitely a numbers game, and it's run on the fiscal year (November 1-October 31). At the beginning of the year (where we are now), waivers are not going to happen, period. Towards the late September/October timeframe, if the Army is short on its annual goal, they'll open the door a little wider to people who need waivers, whether it be educational or legal.
I used to be a recruiter, so I know a thing or two about the regs/requirements, and what the army will/won't allow. At the height of the war(s), waivers were a piece of cake (and this is why you see so many soldiers with tattoos on their necks/hands right now, which is NOT allowed). During a draw down, they're extremely tight.
Guy '87 944 (first porsche/project car) |
this is not correct? this friend was went thru the indictment process, but never prosecuted.
poof! gone |
drunk and stupid
18x requires top secret.....there are a few only requiring secret including interpreter which would be my suggestion assuming he does well enough on the DLAB to qual for a theatre language
