A basic battery question....
Once in a while in the winter I put the battery charger on my Boxster battery. The kind of battery is a Canadian Tire product about 3 years old. It has the screw caps(6) on top presumably to put distilled water in.
The question is this - should the screw tops be removed while I am charging the battery? Perhaps the caps are vented anyway. How does it work with sealed batteries - are they vented? |
Unless you are really cranking a lot of amps to it for a quick charge you should be fine without removing the caps. Any trickle charger will be fine.
Yes. "Sealed" batteries are internally vented. Sherwood |
| All times are GMT -8. The time now is 08:58 AM. |
